New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
Quote from: oouthere on August 09, 2007, 11:22:11 PM
Quote from: hartiberlin on August 07, 2007, 06:30:44 AM
Hi All,
Bob is back from hospital,
he just wrote me the following:
Hi Stephan. Just thought I would give you a little message and let you know I am back home again. I still go to therapy but things are comming along.
The compressor in the movie is what I was the machine was driving to do some usefull work. The machine wasn't ballanced and the board that is moveing is used as a shelf or small table.
There are no hoses or airlines conected to it.
The way to lift the weight to the opposit end is at the 4:00 oclock position an  arm from the centre, on a cam mecanisum to the end of the arm (2.5 ft) is forced around and lifts the linked weights 1" farther than 1/2 the total travel. Centricical force will lift it the rest of the way. It acts like a leaver 2.5" to centre and 10" past.The farther it pushes the weight from the bottom the easier it gets.The first 2" is the heaviest. The spring mecanisum helps at the first of the upward stroke.
A locking pin is used to release the springs.(springs have to be compressed for the first revolution) Springs
On the pictures that are labled, the belt is a steel bar joining the two weights.
The spring mecanisum is at the end of each arm. This is a must, as well as the air shock to stop the weights from impacting the end.
I hade help from a friend,George,who was an retired Engineer who designed the cam system as well as other parts.
I am going to go now. I can only type wih my right hand and it takes forever to type this. Soon I will be back to two hands.
Don't worry about the little bit of trouble there was, everything is ok.
I will be in touch......Take care Bob.
The video states "Uncrank the disc brake, give it a little nudge and away it goes.  Adjust the tension on the brake to control the rpm as there is no load on the first test."
Is this a minor contradiction?
Rich
Maybe he was not really driving the air compressor at this test,
but just the hoses, so these hoses just shook..?
helmut
[/quote]
Rich
[/quote]
[/quote]
I think that the excess Energy will continuisly speed up the Mashine.
therevore he :Adjust the tension on the brake to control the rpm ...
(instead of a load wich workes as a resistance)as there is no load on the first test
(such as a generator to consume the excess power)
helmut
syncron
QuoteHey, Guys and Gales,
Youtube's got this video:
http://www.youtube.com/watch?v=4uLPMGrMohc
it's so simple and ingeniuos yet a 3 years old can understand the how to assamble the device!
Maybe it cannot power a generator, but if you make it big enough to roll in a giant circular runway, you can extract electricity from this wheel with magnets and coils embedded in the walls of the runway.
Just my two cents of food for thought.
Aaron5120
Hi Aaron: have you seen the 2nd part of the video? Look at this.
http://www.youtube.com/watch?v=zEgiZPGKQ_Y
Why he/she burns the wheel?
And another wheel:
http://www.youtube.com/watch?v=AsSTE1T4doc
nwman
All,
I really hate these videos because they are so ridiculously inconclusive and bordering on the edge of silly. First of all from my knowledge of construction a garage floor is slanted to the door by about 3+" over 20ft which would be enough to make those wheel roll the way they do. Now you might say he shows a level on the ground. Well that 5" level would show level on that slope. If you put a 6ft level it would show its not level. He could have so simply shown a video with the fallowing and I would be convince no question. All he would have had to do is start it the way he does in the video and let it roll for 4+ft like he did. Then without cutting the video grab it and stop it and turn it 180 degrees and let it go and show it backtracking the same path to its starting point if not farther. This would have conclusively shown its effects. That simple. But I have yet to see this. The whole burning the wheels thing just makes it so if someone asks him to show the previous he can say he doesn't have it anymore and that you will have to make it to try it.
Tim
I didn't spend the time reading the whole post so if someone already said this my apologies. And as always I hope I'm wrong.
syncron
@Tim & Aaron:
I just made a replication of that simple toy-wheel, even better made as the one shown in the video. Results: the video is a fake, such a wheel no goes more than 4 or 5 turns when you give it a good impulse.
If you want I can put here a video of my replication.
syncron
