New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
fletcher
As far as Mr Hall's attempts at self sustaining wheels go I think we should take into consideration his credentials & background as an artist. While his manufacturing skills look very nice his experimental technique needs some tidying up, to be convincing.
As Tim said, you need a far longer level to gauge accurately the flatness of the garage floor. A short level is notoriously unreliable & shows only the 'local' spot. A longer level [4 ft plus] placed on top of a straight length of timber is an even more reliable indication of slope over a longer distance, especially if you also turn the level around & the 'bubble' remains centered.
Running the wheel both ways evens out any 'slope' anomalies that may or may not be present. Running over different parallel tracks in the same video also helps establish credibility, with at least one track at 90 degrees as well.
Video's need to be continuous & pan in & out to show the surroundings, to eliminate any possible outside interference criticism. The sound needs to be on to eliminate any untoward noises like leaf blowers or air compressors or people on hands & knees blowing or waving a tennis racket above it, for example.
The model has to be shown front, side & back to eliminate any obvious 'coins' taped to the rear side to provide the initial start up over-balance.
There are more 'grey areas' that could be addressed. Perhaps Stefan could set up a thread that gives a list of what is considered good experimental technique for 'Proof of Concept' demonstrations for gravity wheels ? Just a thought !
nwman
d3adp00l
It is building code that garage floors be sloped as nwman correctly said, They do this so cars can drive in but rain water can't get into the house. And even with a 5 inch level, a paper shim could correct it if it could show the out of level. I will say that the mans wood working skills are top notch and very clean.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
Joh70
syncron, yes, why not put the video here? i asumed its not working, because its to easy - no combined mechanisms/principles. Nonetheless i beleave bessler gravity wheels work. For example: i saw one ten years ago on an exhibition for motors/drives here in germany as an eyecatch on a table (not to be sold, not part of the product-portfolio of the company). it was pureley out of metal. but they didn't show me the complete interior but, statet that it was running by its own. i said, thats impossible and went away soon. but i changed my mind some years later and began to start research.
syncron
hi joh70
here you are the video. My digital fotocamara has no sound.
About the setup you have seen in Germany perhaps it was this:
http://www.overunity.com/index.php/topic,2993.0.html
The person who saw it and made the flash told me that this was a "Elektrizit?tsfirma" on Hannover fair.
Sorry I don't succes to upload the video file. I have to compress it. Will try later.
