New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
helmut
Quote from: hartiberlin on September 09, 2007, 07:57:54 PM
Hi Tao and all,
the principle of this device is pretty simple.
I have understood it by now.
You can try it yourself very easily.
Just take 2 x 5 Liter  buckets filled with water.
One in each hand.
Now pull your hands 180 degrees apart and rotate the 2 water
buckets in a vertical plane.
See, how strong the centrifugal forces are and so the water
stays in the buckets and will not spread onto your head ! ;)
Now now retrieve one bucket , so that you hold it with a tightened
muscles, so it stays a bit less way from the center of rotation.
Now let this retrieved weight bang at 12 o?clock against a "mysterious"
wall, which transfers the bang energy to the nonretrieved full arm long bucket
at 6 o?clock.
This will make the 6 o?clock bucket jump into the direction of the center
of rotation.
The 12 o?clock bucket still stays full long arm out until it itself reaches 6 o?clock,
where the other retrieved bucket is again loosened at it hits also the
12 o?clock  "mysterious" wall, so the energy is again transfered down to the
other bucket at
6 o?clock , which will be retrieved then again into the direction of the center
and fixed their, until it is again let go at shortly before 12 o?clock.
So the lever arm from 12 o?clock to 6 o?clock will always be heavier
and the resetting is done via the immense centrifugal "fictitious force",
which is thus converted into a real force doing work !
Regards, Stefan.
@Stefan
Please make a sketch for those,who can not imagine that lesson.
helmut
Quote from: tao on September 09, 2007, 11:38:55 PM
Site down http://www.newenergymachine.com/
Says it will be back in a couple days in the title................
it seems he registered a new domain name for this:
www.newsourceofenergy.com
zero
Stefan,
I also would like a sketch, because Im having trouble understanding
what you mean.
Prophmaji
LookÃ, on the net, for a video of the innards of a wankel engine and then read again. Then you will get it.
http://en.wikipedia.org/wiki/Wankel_engine
About half way down, and on the left of the page will be an animation of the action of a wankel. Imagine the piston being a long bar, with a weight at each end, instead of the wankel's tri-corner unit. The piston changes position, ie, it flies down the right side with the weight way out there and as it approaches the bottom, it is slammed up to the center and the opposite end of the dual weighted bar (like a dumbell or weight bar with weights on each end) is slammed to the top. The whole arrangementÃ,  (the long dumbell bar with weights) is located on a flat or guide that is twice as long as the dumbell, and that rotates, while the dumbell is constantly trading ends around. Like the wankel engine, but with only two piston 'tips' instead of the wankel's three.
You will quickly see how the rotation and slamming combined with the "baseball pitcher" like action of tossing the end out like that will cause or create huge amounts of torque from a fairly small initial pulse, that is acelerated via the centrifugal force. It's like a underhand softball pitch that hits a wall at the bottom of the pitch or near the ball relase point, that forces it upward. This is done at the bottom of the motion for the same reason the pitch in softball is released at that point. It is the point of highest energy accumulation.
Imagine this: You have a softball in your hand. There is a steel bar running through the center of it. The bar is attached to your shoulder and sticks out just past it. Another softball is attached to the end of the bar that is just above your shoulder.
If you were to reach down, grab that softball,and move it up..the bar would slide through the rotating anchor that is at your shoulder joint, and the upper ball would begin to move in perfect sync with the lower ball. They are tied by this steel bar.
Now, rotate the softball (the lower one) around quickly and both will rotate, one ball way down low, and far out - the other, at your shoulder, rotating around the joint.
Now, imagine a wall in front of you, or a stump or the like. Now, you rotate the ball around, way way out, as far as you can, to gain energy for the pitch. But, when you go to release it, you hit the ball on the stump, near the ground. Pow! The forward momentum of the ball is ended, but the ball jumps upward, toward your shoulder. The one that was near your shoulder, goes up as it is tied to that steel bar that is anchored at your shoulder. The lower ball comes up to the shoulder point, but the other one goes way up! Now the upper one..which has swapped positions with the one you pitched.. will do the same as the first, as the steel bar they are both on and attached to your shoulder..will continue to rotate.
So it's torque..accumulate.. slam! (swap positions) torque.. accumulate (energy).. slam!.. (swap positions)..torque .. accumulate (energy).. etc
That is the essential point of operation.
Now guys, did I get it right?
