Controller circuit for Hilden Brandt motor needed..
Started by hartiberlin, May 19, 2007, 12:56:53 PM
Honk
OK, let us use the points. No other solution is needed to get the motor up running.
All you have to do is to connect the points to the controller input and the valves to the output.
There you go....
Magnet Power equals Clean Power
dingbat
QuoteHonk & dingbat,
Seems like this thing is getting very complicated again.   I think Gregory has a good point.   The turn on of the coils does not need to be complicated, the points will do the trick.    If we need to go to something other than that, I think it should be either electric eyes or hall effect switches.     Something that I understand and can work with.    dingbat just does not seem to have time to come down to my shop to work with this kind of stuff, so I need it simple.
Later,,,,,JackH
Sorry.  Just forget about the encoder idea and proceed with what you understand.  That will be the best solution for you.
shruggedatlas
The suspense is killing me.  Does the motor work?
Honk
Quote from: shruggedatlas on August 07, 2007, 12:13:58 AM
Status Report:
Jack's motor is working just fine, like his other motors.
An earlier 2 valve motor from Jack has proven 200W out while consuming 130W, according to Jack.
His new 3 valve motors will work even better and their design is also improved to increase the performance.
Right now I have to test the controller on a real valve to make sure it will perform it's best on Jack motor.
I have been trying to convert some old transformers into a valve but it was not successful.
The machine shop I used at my work was not accurate enough to handle the fine tolerances needed.
Now I will try to buy some Non Oriented Silicon Steel and ship it to a friend of mine which will cut the
steel laminates into the desired shape by laser. By this way I will get myself 3 pcs of acccurate valves.
In these valves I will use either N52 rectangle or N42 cubes of neo magnets.
I hope these last readings really turns out good, before shipping the controller to Jack.
In worst case I'll have to ship the controller without having it tested on a real magnet valve situation.
/Honk
