John Kanzius: saltwater can burn!
Started by majkl, May 27, 2007, 07:30:40 PM
Moab
Quote from: kukulcangod on June 20, 2007, 06:07:15 AM
Once I got lazy and heat up a cup of water in the  micro for a couple of minutes or less but what surprised me was that as soon as I put the stainless steel spoon in the liquid this started to boil up! no sugar no tea , just water and steel..... is this related to what Kanzius got? , Now for sure the setting has to be very precise because this doesn't hapen everytime or ever since  I just calculated by feeling when the water was ready
it always puzzled me this result but let it in the back of my mind of course......
Where can I learn more about high frequencies and harmonics with not to technical terms?
Thanks for the feedback.
Good luck to all.
The guys in the TPU-ECD thread are getting into Ferq and harmonics. Moab
Paul-R
Quote from: Moab on June 21, 2007, 08:40:39 AM
Good luck to all.
This is because of the effect of microwaves on metal. If you go to J-L Naudin's
site, you will learn how to make ball lightning with your spoon:
http://jlnlabs.online.fr/plasma/gmr/index.htm
Paul.
Dingus Mungus
Quote from: Paul-R on June 21, 2007, 09:59:56 AM
Good luck to all.
Paul.
No its not... Its surface tension. The water is at an adiquate temperature to begin boiling, but the surfrace tension creates just enough pressure to raise the boiling point of the fluid. Once you break the surface tension the liquid explodes with heat and begins to boil very quickly. Its a pretty easy experiment to replicate, and I promise it requires no metals.
~Dingus Mungus
giantkiller
Better yet...
Take an 8oz glass tumbler, fill it 50/50 with ammonia and bleach. Drop a steel spoon in it and put it in the microwave for 2 mins. This will give you enuff time to get away.
--giantkiller.
Dingus Mungus
Thats sounds like a bad idea...
What if you just overheat a plastic cup filled with water and throw a plastic fork in when its done.
I promise the water will "explode" once you break the surface tension.
