Huge on Demand Hydrogen production
Started by hartiberlin, May 31, 2007, 07:42:22 PM
hkyle
If I was to guess I would say coal and Calcium chloride. Calcium chloride is made from salt and It is highly soluble in water. This creates an exothermic reaction.
Just guessing. Could be all wrong. ???
It?s easier to be forgiven than it is to get permission....
Bruce_TPU
In the video he made mention of "something used in the mfg. of glass"  and something we are "walking on".  I agree with Stefan, a type of silicate perhaps.
Very cool perhaps great potential.
Bruce
hkyle
and correction
Ferrosilicon and Sodium hydroxide
hartiberlin
Hmm, I got an email stating this:
STOP STOP STOP... Thank you to all of you!!  Everyone keeps on writing to me because someone LEAKED a copy of our video.  We sent it to a few people for feedback and before it was finished it was going around the net. All of you who we sent it to ( you know who you are) You'll NEVER get a preview sample from us again..ever.. Here it is:
http://www.youtube.com/watch?v=TinQ3iV403s
We finished it real quick and then added some more stuff and put it up on YouTube for you to watch. HUGE Hydrogen Flames... The chemicals are easy, cheap and you're walking on them.  They are made from Salt, Sand and Water.   That's it. We're working real hard to get the 9 new books and the new Roy McAlister DVD up on the site so you can get this good information.  Keep an eye out for an HTML email from us with plenty of pretty photos and it will have the links in it on how you can get the book, The Chemistry and Manufacture of Hydrogen and the Chemistry and Manufacture of Hydrogen DVD that Steven Harris and Roy McAlister did last month.... We only have 3200 of the DVDs and it'll be 4 weeks before the 2nd batch arrives... I have to get back to writing the email and the ad so keep an eye out for it and get the DVD if you like, as soon as you can because I think we'll run out in a day or so based on past sales.  Don't worry... we'll get plenty more for you. Thank youSteven HarrisCEO, Ad writer, bottle washer, KnowledgePublications.comKnowledgePublications.com 8243 DartmouthWarren, MI48093US
Hmm, what kind of sand coud it be ?
How much is the book and the DVD ?
Bruce_TPU
Hmmm...Look what I found... ;)
Silicon
There is a fair amount of disagreement in the books and on the web about what silicon does with water or steam. The truth seems to depend on the precise form of silicon you are using.
The common shiny grey lumps of silicon with a rather metal-like appearance are fairly unreactive. Most sources suggest that this form of silicon will react with steam at red heat to produce silicon dioxide and hydrogen.
But it is also possible to make much more reactive forms of silicon which will react with cold water to give the same products.
Note:  These more reactive forms are produced as powders. Cotton and Wilkinson's Advanced Inorganic Chemistry (third edition - page 316) suggests that the reactivity of one of these could be due to a very high surface area, or perhaps because the silicon exists in a graphite-like structure.
A correspondent from the silicon industry tells me that when silicon is cut into slices, the silicon dust formed reacts with water at room temperature - producing hydrogen and getting very hot. He says
"The silicon is cut in a glycol slurry [. . .] The powdered Si is protected somewhat from moisture in the glycol slurry, but when we clean the slurry in aqueous solutions the reaction with water takes off."
This is probably the effect of the high surface area of the dust produced, combined with the fact that you are exposing uncontaminated silicon to the water. One source suggests that the lack of reactivity of silicon is due to a layer of silicon dioxide on its surface. If you expose a new surface by cutting the silicon, that layer won't, of course, exist.
AND
Reactions with water
Sodium
Sodium has a very exothermic reaction with cold water producing hydrogen and a colourless solution of sodium hydroxide.
http://www.chemguide.co.uk/inorganic/period3/elementsreact.html
Thank your for your time,  (A "mini" break from TPU land!)
Bruce
