all you need is spead diode to make tpu bealivet
Started by MACEDONIA CD, June 02, 2007, 03:57:49 PM
Motorcoach1
Thank you : please post in the best english you can, we will try hard to figure out what your saying . Ignor the pesters. you mean well and keep working . Mike
Bruce_TPU
Actually, if we can find an Online macedonian translator, that might just help.  Has anyone tried to translate the above message online?   ???
Cheers,
Bruce
maxc
hartiberlin
hmm,
would be nice if someone could translate his words.
8 Watts Input and 50 Watts output sound great !
How did you measure it exactly ?
Thanks.
Regards, Stefan.
DigiLab
Quote from: wattsup on June 07, 2007, 02:18:40 PM
Geez. When it's not SM's stereo parables or Erfinders mystisism, now we have Macedonian tid-bits.
Who's next?
I like this. This is funny, genuinely funny :). Made me laugh first time i read it and I am still laughing when I read it again  :).
Ok, I'll try to help. I am Macedonian so the translation is not a problem, here it goes:
Start of translation
Hi, Ok I don?t type English but I type Macedonian Language. If you have problem with my English then I will type Macedonian.
So, like this, it?s very simple ............. I want to say that diodes are alike this transistor BUZ11A...... that?s first. Second, if you have one copper wire and if it?s long 1 meter and if you move small magnet close to it you will acquire on the ends of that wire some voltage but that voltage will be small,,,,, but if you wind 1000 meters of copper wire and if you move the same magnet with same velocity around that wire, than you will acquire higher voltage   ??? ????? But you will not obtain Amperes, so what you have to do to obtain Amperes ,,,,, you will take 1000 pieces with length of 1 meter and connect  ??? ?????,,,,,< I live that to you to put some effort to figure it out >>>>>> I have solved this problem, I leave it up to you to figure it out. Than you will find Amperes. Than you will need fast magnetic field but not very strong which will interrupt and enter in <<  collector coil..
Then you will have the TPU but still there is one more problem  ??? .When you will understand that then one other minor problem will emerge. I live that to you. And for the end of this explanation I have to tell you something in order not to lose faith in this. I did this with following characteristics <<<<<<< 8Watt in about 50Watt out electrical energy >>>>? All this what I have said is true
Believe me, when I see video clip or picture that some of you did something with this explanation and if he experiences some problem I will help him. Only if I see that someone really is trying to make it than I will help. Thank you for your time. Thanks to all in this forum.
End of translation
@Bruce
I like the energy that you brought to this forum. I personally think you are right on the money, just have to iron the details along the way.
Godspeed
Macedonian
