Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
0 Members and 23 Guests are viewing this topic.
tinu
Quote from: hansvonlieven on September 09, 2007, 07:15:23 PM
Sorry Tinu,
We still haven't discussed the Chas Campbell device, only the gravity wheel. In case you have forgotten I post again the diagram given to me by Patrick Kelly from Panacea.
Any comments on this????
Hans von Lieven
lol! that's an easy one.
comments? yes, one, for the inventor: make it work first...
hansvonlieven
Sorry Stefan,
I missed nothing here, it is not a question of torque in the above example, it is a question of INSUFFICIENT MOVEMENT UNDER TORQUE.
The longer the lever, the more it can lift, true, but also the longer the travel of the long side of the lever to gain the same HEIGHT of the load as with a shorter lever with the same amount of travel (in degrees)
Hans von Lieven
rMuD
Quote from: gaby de wilde on September 09, 2007, 07:28:46 PM
http://img.go-here.nl/chas-is-cool.png
Quote from: hartiberlin on September 09, 2007, 06:59:06 PM
good idea with the SMOT ramp.
If Chas is still buying the real big ball bearings he could really use it and get it
overunity this way for sure.
I think the device can be much smaller like this?
It will be more complicated to drop the balls out of the smot in time.
The image also tries to illustrate to curve the ball inwards. Pulling the mass towards the center should accelerate the wheel.
My instinct says it should give more leverage as just leaving it on the rim you see. ;)
if you got a working smot, it would work...   could think of a better way to gain energy from it..  also you would need to adjust the number of ball catches on the upswing to account for the gain in outer wheel distance.
your spiral ramp?   when would the balls be adding mass to the outer wheel?  we need to increase the time the outer wheel has mass to lift the mass on the upswing.
maybe we could teleport the balls to the top, skip the inner wheel.. or a static worm hole
Humbugger
Quote from: Humbugger on September 09, 2007, 07:22:49 PM
Stefan
I want to hear how Charles arranges a whole number of ball receptacles at 29 degrees each yet evenly around the wheel.
I have been accused of inappropriate use of ridicule.  It is only fair that I be shown exactly why the idea of building the wheel with 29 degree increments is not ridiculous.
Then I will voluntarily ban myself, cut off both my hands, pour the remainder of the Glen Livet into my eyes and light it on fire.  I promise.  And swallow the pill Hans is supposed to be keeping.
Humbugger
in lieu of any explanation, to avoid ROS, i must apparently agree that the Charles wheel will probably only work when fitted with an appropriate pair of powerful SMOTs so that the balls will roll rapidly uphill.
then limitations imposed by the feed and return ramps will be removed.  there can be six balls on the right side with any diameter.  the SMOTs can maybe lift the balls almost vertically, so maybe only five balls on the right, six on the left.
but the distance can be anything, fifty to one even a hundred to one.  the machine could have a lot of power with the right pair of SMOTs and the giant steel balls.  zero's ideas can be worked in for an extra boost.  Maybe the SMOTS can fire the balls hard at a 45 degree titanium plate angled to reflect the extra additional forces into the direction of rotation.  Hmmm...
Humbugger Caves In        after only Five Whiskeys ~ Must be getting old...
hansvonlieven
G'day rMuD,
Ever heard of Cavorite??  That is the shot here to make this thing work. :-)
Hans von Lieven
