Newman machine replica
Started by TheOne, June 08, 2007, 06:55:48 PM
potatogunman
Hello  !!  Great stuff guys!! .... i am  planing on  building  a newman machine ,,as i seen on Youtube A guy called "chuck2" built one ...but i would like to know  some details  about the wiring .
On Youtube Chuck2 descibed  the wiring ..but i couldent  make  out  some of the details... I  Drew a Picture   witch ill post  below on what i could make out...
if it needs  any corrections , please feel  free to copy  my drawing an re-post it
thank you  soo soo much in advanced!  :John
Dingus Mungus
Neat design...
It's not exactly what we're building here though. In the design you see here the battery is located between the constant contact on the shaft and the stator coil. I should point out though, If you wound the coils to match the magnetic geometry of your shaft the design you posted would work to turn the shaft. I don't know how it would effect the BEMF spikes, but it would be interesting to see it tested here.
Good luck on your replication!
~Dingus Mungus
EDIT: HA! I was just thinking, and that design could be used to pulse twice a rotation with dual contacts... Once again though I'm unsure of how that would affect befm. Thanks for posting and welcome to the community!
potatogunman
Thank you for the warm welcome!! ;D   ....i  have another idea  ..ill post  a pic of it soon
Dingus Mungus
Please try to post photos and if possible scope data of your replication efforts.
This thread is really for replication of Newman/Chuck2 design. If your idea shows results though please post as much info as you can as we will try to replicate your design if that is the case. In the mean time though I encourage you to read the whole thread and attempt to replicate the low consumption high resistance motor design.
Good luck,
~Dingus Mungus
hartiberlin
Quote from: potatogunman on July 04, 2007, 10:19:11 PM
Hi John,
the lower red coil is wrong polarized.
You just need to connect the output pins ofthe red coil exactly the other way around,
if both blue and red coil are wound the same direction.
the 2 coils must work as if it is just one coil. So they are just put in series.
But you have it drawn it in Bucking mode...
