Newman machine replica
Started by TheOne, June 08, 2007, 06:55:48 PM
TheOne
the wiring is easy, you use the coil, one of the wire go to the negative side of the battery, the other touch the shaft (like a pulse) and the positive side of the batterie is connected to the shaft directly
seekingknowledge
Thanks the one so where should the magnet be when the wire touches, eg should it be at the part of the revolution when the 2 magnets a vertical or horizontal?
TheOne
i was doing that but i am not sure if its the best location, but when the magnet are at the opposite of the coil field its prob the bigger push you can get
CLaNZeR
MRamos
I shrunk your Video and sent it back on email, did you get it okay that end?
If not do you want me to upload from this end?
Cheers
Sean.
http://www.overunity.org.uk
CLaNZeR
MRamos's video attached.
********* Tried to attach but same problem with timeouts so have popped it up on my server and link below ***********
http://www.overunity.org.uk/mramos.wmv
Good job Mike!!!
Back to the workshop here, things are going well and will catch up on posts later :)
