Newman machine replica
Started by TheOne, June 08, 2007, 06:55:48 PM
CLaNZeR
Quote from: Dingus Mungus on June 18, 2007, 05:33:45 AM
Here are some pics of my replication.
Working on the pot motor now...
~Dingus
edit: a video also...
Looking good Dingus.
Can you explain more on how it works?
I did a search on google for Newman recipricating Motor but did not come back with a lot.
Cheers
Sean.
http://www.overunity.org.uk
CLaNZeR
Quote from: jorgerojo on June 17, 2007, 11:34:45 PM
At last some one who think about teaching us Mortals, that do not understand much of electronics, a lot of people like me are following you, thats for sure.
Hi Jorge
Thanks for that :)
I do not understand that much about electronics either LOL :). I am all self taught an just pick up what I need to know on each project. Dun't think my brain could hold as much info as other guys on these forums.
What I do like to do though is share the build info as I do it, because if I finally get something to work, then people will see how it was made and should be able to copy it. I am all for Open Source and sharing with others anything I learn on my journey.
Sean.
CLaNZeR
Quote from: mramos on June 17, 2007, 11:35:31 PM
Sean, just popping in to do the same (skipped the empty promise guy lol).  Back to my real job tomorrow.  Weekends go fast for sure.
Coil looks good.  Let me know what you find with it.  Mine has a crossed coil in the middle, like the window motor.  Odd thing.
I went back and looked at my pictures from a couple nights ago as the battery was at 11.24V (at rest) this morning.  Somehow it went up.  Tonight it is 12.04 volts.  Very weird.  I ran it for 15 minutes maybe today, when I had a second.
Also, I notice the motor will run along, then after so many minutes, it takes off at a much higher RPM (for maybe a minute) then slow back to what I would call normal speed.  If it was the tape giving up it would not return back to normal.  I have seen it do this many times.
Waiting to see what you get next weekend.  Will keep playing here tomorrow night.  11:34PM and tired as heck..  Nice work as usual.
Mike
Hi Mike
I have been thinking about the tape replacing side of things.
How about just stripping of the PVC cover of some 6MM copper wire and using this. Simply cut a Window in the PVC and slide it over the shaft?
Strange like you say about the increase RPM's and then dropping off, be good to pop a tacho on it and measure the speed.
Back to work for the week this end :( but will play more next weekend and hopefull have a spinning motor atleast :)
Cheers
Sean.
Dingus Mungus
Quote from: hartiberlin on June 15, 2007, 02:29:14 AM
Hi Dingus,
if you go with the reciprocating setup, where a magnet just slides in and out of the coil,
you have to make this circuit like a door ringer bell.
So connect one contact point to the bottom of the magnet and the other
beneath it.
So if the magnet falls into the coil it makes contact and the coil
repells the magnet out of the coil and the contact is broken, so the magnet
again falls back down making contact again and is repelled again out of the coil.
If you go with the rotating setup, you just need to make
contact once per revolution of the magnet at the right angle.
So you stick the contact to the axis via a commutator.
Pretty simple. No higher mathematics needed ! ;)  ;D
Regards, Stefan.
P.S: Replace the 10 ohm shunt with a incandescent bulb.
The shunt was only there for the scope measurement for
to see the back current spike on the scope.
So I tested the reciprocating version first just to see a simple proof of concept.
Its a 12v 4ah backup battery, 200 feet of 30g wire, and two 1"x.25" neo cylinders.
From positive terminal the coil begins and the last 2 feet were left to connect to the
floating magnet. Once the magnet is levitating on the other magnets field you can
add a tin foil contact in the tube between the magnet and the negitive terminal, when
gavity pulls the magnet down it closes the circuit and the magnet is repulsed up the
tube. When it falls back to its start position it creates a high frequency BEMF pulse
that will really mess with your meters sometimes. An interesting proof of concept.
~Dingus
CLaNZeR
Quote from: Dingus Mungus on June 18, 2007, 07:39:44 AM
~Dingus
I understand all that I was wondering where the Cereal packets fit into the circuit hehehe  ;D ;D ;D
Again good work Dingus
Cheers
Sean.
