Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
c0mster
Folks
I was there, I was the dude trying to calculate watts. This looks real promising, however because Jason and Otto , not to sure about Otto?s tests, but Jason is using a power supply connected to mains and like some of you have mentioned it the RF could be affecting the power supply. The last calculation based on the power source meter showed about 143 watts, this does not make sense. To prove the fact a battery needs to be used as supply. If  the unit is gathering radiant energy supplying back to the battery would prove useless, remember SM used a converter to run the TV etc. A true test would be to use a battery and replace the light with a resistor, calculate the wattage draw at peak performance and the wattage output at the resistor. A battery will be more forgiving of reversing polarity and the battery can be scoped on ac to see if there is charge back. Of course I am building one. As always I don?t just sit here and post I prefer to do the work and help others. Keep it open source and free. Keep greedy capitalist out.
gaspo100
Quote from: MeggerMan on June 12, 2007, 12:25:55 PM
Hi Peter,
Excellent news.
Are you sure that if all 3 DDS chips start with same master clock after a soft reset they will stay in Sync?
I can use a different DDS chip, it does not need to be the AD9833.
Rob
I have built triple DDS generator with AD9834 and used RESET pin to synchronize them. I'm quite sure that Analog Device's documentation states stopping the clock as a way of synchronizing the multiple chips.
Here's the schematic of my DDS generator I built in January. I'm controlling them with AT91SAM7 board.
Initially I used PC program to program DDS via ARM7 board. I'm currently building a separate keypad and LCD display to for attaching to ARM7 board to have it self contained and independent of a PC.
Peter
Hoppy
Quote from: c0mster on June 12, 2007, 12:46:12 PM
Folks
I very much agree. I've been working for a couple of years with Bedini technology and have witnessed all the effects being described. I've had 12v / 50W lamps blow on what appeared to be low bench readings. I've had more than one bench PSU destroyed and in consequence I no longer use these when experimenting with Bedini Energisers. I would therefore urge all those currently testing TPU's to pay special attention to what has been suggested in the way of properly checking current and voltage levels. My bench supplies failed  to regulate because of the HV spiking and delivered their full power to my energiser. You should have seen the brightness of my lamps! Take another look at the video and notice how the LED / LCD meter readings are wildly fluctuating.
Like all of us I'm aching for a breakthrough but what I'm reading so far seems to be very familiar to me.
Earl
You can ramble on about this and that, but it doesn't change the hard, card facts.
The mentioned video was made by someone, who in my opinion has no brain and did not make it through kindergarten.  You obviously have no clue about what constitutes power or you would not have mentioned this video.  Don't lecture me about letting old ideas go, I was researching FE and thinking outside the box probably before you were even born.  Being infinitely stupid has nothing to do with furthering research into the unknown.  Sorry to be so frank, but just because any idiot can post a YouTube video with the phrase "Free Energy" and I get upset does not mean that I think the world is flat.
With my experience I have the obligation to speak up when a novice attempts to turn the group down a road that is hopeless.  Before you make any reply, watch the video again, write down the results, and calculate the power levels involved, including instrument accuracy and allowance of noise levels.
SM's TPU doesn't need a magnet to operate; he only uses it to eliminate an internal battery.
Regards, Earl
Quote from: Merkhava on June 12, 2007, 09:33:23 AM
Earl,
Go look at the SM video's of the TPU. SM started them by placing magnets on his device. Our goal is to replicate SM's deivice, self contained, free-running with no harmful RF emissions and no need for shields.
For this research to progress, you may have to let go of your old ideas taught to you by the orthodox high priests of electromagnetic dogma. The world is not flat and the sun does not orbit the earth.
Just pay attention to the SM videos and think about what could possibly be the reason why a magnet placed on the unit by SM would make it start?
I take no offense at your cries about "stupidity". This research fundamentally demands a questioning attitude of all our postulates and theorems about electromagnetic phenomena.
The orthodox have always cried heresy against pioneers and their new ideas that forced paradigm change.
Robby
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
turbo
Finally..... 8)
This is just awesome.
If i understood correctly the vertical space between the two 4'and 6' coils is not really nessisairy?
otherwise i will have to adjust my diagram.
Thanks guy's awesome job.
Marco
