Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 218 Guests are viewing this topic.
otto
Hello all,
Im 4 days at home. Must not go to work. So Im playing with coils.
Today I wanted to know how many turns should have my primary coil of my little transformer. I did a loooot of tests. I spent a lot of hours, cutted my primary coil, measured....result NOTHING!!!!!
The point is: THE DIAMETER AND THE LENGHT OF THE PRIMARY COIL IS NOT IMPORTANT!!!!!
First I had a 12m long coil and pulsed this coil. Signals fine....then shorter and shorter and then I saw it: at a frequency between 50 kHz and 60 kHz I could clearly see SINE WAVES!!!!! This happens at 12m or 2m lenghtof my coil.
Yes, I know what Im wrighting. The lenght and diameter is NOT important. To see sine waves the frequency is important.
This sine waves I saw with a 0,5mm diameter coil even less then 2m long!!! Just 1 frequency and a wire. But I have to say that everything is connected like in a TPU: I have the Mobius and my pulsed MOSFET is on a copper plate arround 5 x 3 cm in dimensions and 1cm thick. Of course I can also see the seeds. They are so little that my scope is in the range of 200mV. Then I can see the seeds.
Dont ask for a picture because my camera is "out of house". The seeds and the sines are the same as in the pdf. Oh, no, not the same because I have no secondary coil. The sines are arround 10 - 15V.
Now, Its clear why we need a secondary coil, or to say it better, why we need a little transformer in our TPU:
In the primary  at 50 - 60kHz sine waves are created and the secondary coil is an amplifier.
Just look at the open TPU. Try to see how many red wired windings you can see.
Otto
giantkiller
So it sounds like:
you pick the total length of the primary,
then calculate the mass length of the secondary,
Find the resonant frequency to the primary,
and you have accomplished the seed step.
Here is a half done spread sheet to do this. It is hard coded for 30awg and 26awg. Change it accordingly for your needs.
--giantkiller. No? Yes?
turbo
Otto,
It has been 3 months now since you claimed you had a WORKING TPU and you claimed you could PROVE it.
That certainly catched my attention and i dropped all my experiments aswell as all my research activities to catch up with you.
You told "us" we were wasting our time and all our coils were wound the wrong way.....etc.
I was wondering how can you be so sure since you do not have any idea of what i was actually doing.
Now you are talking about the number of turns...
This makes me think....
I guess we all know what happens when we wrap bifilar coils with variable number of turns.
It is called stepping up.
untill now i have not seen any real indication of your so called "creation of energy"
Here is a pdf, so you can see what you claimed, in case you forgot.
I am going to continue my own experiments because they were going quite nicely before all of this.....
Marco.
MrMag
Otto,
I do believe what Marco is saying. The way your primaries and secondaries are wound, you are setting up a setup transformer. I could be wrong but this is what it look like to me. Also, the 50 Hz signal you are now getting is probably coming from your mains supply. Do you have fluorescent fixtures near by?
Tim
MrMag
I mean step-up transformer not setup transformer. Sorry.
