Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
dutchy1966
Hi Gustav,
Very good observations! I've been thinking that for a long time already. Why?
Because SM stated in the very beginning already it is like a hose filled with water. You can move the water by picking up one side and moving it along the length of it. That description can very well descrive a quarter wavelength standing wave!!
So it migth be that we have to rotate this standing wave because he says we have to move it along the length of it.
regards
Robert
Thaelin
   And if your frequency was not quite on target, then it would appear from a standing point to be passing by.
   Just did a test of a twin coil with each frequency originating from opposite ends. Input about 12 p/p on each. Output to scope > 250. Alas, no power tho. Bulb load killed it completely to a 90 degree coil. Resonant point about 350k. Same direction, nada.
sugra
Bruce_TPU
@ Gustav22
I believe you are absolutely right.  This is how the diameter of the collectors is directly related to the frequency and vice versa.  The tech name for this is called directivity.  I posted about it on my thread sometime ago.  It is a weird mathamatical formula, because you have to know the frequency to determine the wavelength as well as the circumference.  It is used for loud speaker design.
Quote from: sugra on June 25, 2007, 08:15:56 AM
sugra
@ EVERYONE
I would add, and please correct me Sugra if I am wrong, but the opposing signal was from a SECOND SOURCE.  A second generator.  SAME source opposing signals will NOT work.  This is the secret.  PLEASE see my last post on my thread for details.  Read it until you understand.  Also read BEP's and Sugra's last post on my thread.
Thank you for your time,
Bruce
ronotte
@Gustav22,
1 - YES, the secundary coil is under the primary (the red coil).
2 - I checked your math and it is correct. The reason why the secundary is just over 9 m (in Otto's design) is only for gain an additional signal onto the 2 rings (1:2 ratio) and because Otto found more power with said lenght.
3 - I find it interesting to cut secundary coil to 7.7 m just to stay in full wave resonance with Cu and in order to have still a good ratio may be useful to cut primary to 1.9 m. (note that I've exchanged primary with secundary..I don't know if this may be done).
As I've to wind the second ECD CC I'll follow the suggestion. Let's see it in action.
Actually I'm thinking that this type of standard math about resonance & standing wave conditions are not so important as the coils are excited by many frequencies all together...it isn't absolutely the case of 1 freq only! so why privilege a single freq?  On the contrary in my personal opinion the coil should be of wide-band kind just to easier the frequencies forming! (please think that the formed sinus is @50 KHZ). Again the actual CC (as in my paper) do show a bandwidht of less than 80 KHz...a possible scenario could be that of study one of the many coil construction alternatives that may lead to lessen the stray intrinsic capacitance and so widen the bandwidth.
Roberto
Thaelin
@Btenzer:
   That is correct, that was two seperate gens running using only the positive lead from each. No grounds were hooked up. I have been trying to figure out how to achive some sort of terminating point for each signal with out using the grounds. Not sure how I would do it.
   If and when I get my fet drives in the mail, I will be trying that again with really short pulse durations. Then I will see if that output has any power asociated to it. Laterz
sugra
