Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 214 Guests are viewing this topic.
Technoalchemist
If anyone can find this "watch battery" video I would very much like to see it. All I ever saw was in the 2 lamps/cardboard box video where the cameraman asked him if there were any batteries, he gave a hesitant, if not sheepish "No.". So I don't necessarily doubt it. While it is VERY true that HAARP modifies the natural resonance, as with EEG attenuation/entrainment, when they shut it off, she (earth) returns to around 7.8Hz +/-, (as do our brains)....lol. There are many ELF, and other study groups that periodically measure and record this data. There are some that exclusively keep an eye on HAARP also. Recent data is available.
SM says "like a simple radio receiver", "variable tuning device", "the multiple frequencies are of too high a frequency to provide any motive effort", re-read the part about magnetometers....very telling. Why would the frequencies be "directly related to coil circumference"? Sadly. I was in a design process of an idea of my own based on Tesla and Henry Morays' work when I accidentally found SMs' work and you all less than a month ago. After reading all this, I kinda thought you almost the hard part figured out. So can you get even a LITTLE electricity out of a EM wave?...of course. How does a radio work. A CRYSTAL RADIO EVEN? But what component of the wave? How does a wideband ELF antenna work? dunno. You all are WAAAY more knowledgeable than I about electronics....very smart people. I think you need a hardcore ham radio guy in here. Unless he was another Stan Meyers, trying to throw youns off the path of his patents (which never surfaced, UEC or otherwise), I think he was trying to give you a COMPLETE pile of puzzle peices, as Tesla did.
jacob
Quote from: gn0stik on July 03, 2007, 10:30:00 AM
Otto and brnbrade (as well as myself and others here) followed the erfinder posts and drew inspiration from them. Otto based some ideas off of the VTA, or DTO, diagram, and brnbrade off of the mcfarland cook patent. Have you noticed how similar they are?
I have to say, if Otto's device is related, then so is brnbrades.
Otto has made claims that his device loses weight, has inertia, etc. already, on ctglabs. when dave asked him more about it he didn't answer. Nobody else has seen this yet. And we've seen lots of behavior of otto's coil that are most definitely not present in SM's device. SM has no problem touching his coils, it's quite dangerous in otto's. Although there is RF in SM's judging by the fire output, there doesn't seem to be massive fields in the room. Much more testing needs to be done. Otto only has bits and pieces of the whole picture. Others will have other parts.
Otto has already said his device is not overunity. From all accounts, that is correct. It's not. No thunder is being stolen, but we have to look at other angles in order to find the missing pieces that will make it overunity.
Have that thread moved back. It's a valid line of research and is clearly NOT disrespectful to SM. And is NOT distracting from Ottos work. They are very closely related, if you look closer..
Regards,
Rich
100% on target.
Thanks
Jacob
jacob
Quote from: btentzer on July 03, 2007, 02:27:09 PM
@ Stefan
I suggest upon successful replication of the brnbrade coil, it be moved BACK to this forum.  I concur completely with Rich in this matter.
Thank you,
Bruce  :)
Ditto!
z_p_e
@ Stefan,
May I suggest that you move ALL the topics with coil-like devices, into the TPU topic?
After all, if they use a coil, they must be related to the TPU somehow, right?
Arg...
Bruce_TPU
Quote from: Technoalchemist on July 04, 2007, 12:34:54 PM
Hello All.
Facinating that people who understand the clues are reaching about the same conclusion on this "bit" of TPU function/mechanics.  It should be experimented with asap as I have been pleading.  Artificially producing a ELF stationary wave, to play over the 3 high frequencies and see if more music is made.  And then exploring means to perhaps do this naturally by tuning the coil as an "effective" antenna as BEP suggests.  I have share before the special attributes of the frequencies given to us.  One is the frequency of the polaris lights and the other the frequency that ac is joined to lightning.  Mix in the ELF with those frequencies and we have power.  That is why it is "tuned" off of the exact Shumanns.
Cheers,
Bruce
