Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
13thHouR
Quote from: pauldude000 on August 18, 2007, 12:40:27 AM
If you are familiar with bill beaty (excellant site) http://www.eskimo.com/~billb/weird.html he does some quite interesting experiments. Check out this one: http://www.youtube.com/watch?v=KGGbCuf2-2I
This is a classic, but why I bring it up, is the important reason. No matter how I visualize particle interaction with the ZP or Quantum flux, it looks pretty much like the floating dry ice experiment. Every particle (dry ice) comes from the quantum flux (the vapors).  Anything penetrating the vapor will have to "shove it aside" to pass through (inertia). I wonder if "quantum tunneling" isn't in fact the Flux absorbing the particle, then re-emitting another like particle elsewhere.
Understand that there is nothing else truly in the universe than the Quantum Flux....... The particles are some form of lower frequency of the flux itself, in a stabilized format. Everything is energy, and what we like to conceptualize as solid... there is no such critter. Sometimes it can be difficult to express or convey mental imagry with such a flawed and fallable device as language, so I apologize if I have done poorly.
That is why any properly high enough frequency in any medium or energy could therefore be assumed to interact directly with the flux.
What I meant by a resonant trap earlier, is something I envision in my mind. We know that in a truly resonant form, the voltage no longer leads the amperage, but is in fact of the same period. If two waves of sufficient difference of cycle are interposed upon the same path, and at all places along the path of the longest wave where the potential crosses 0v, that the shorter or higher frequency waves also cross 0v at exactly the same point, the two waves should travel simultaneously without interference, they should in fact strengthen each other.
Another byproduct is the time gaps between the peaks of the resonant waves. It is no longer filled with current lag, but is at higher or zero excitation.  At the points, my mind shows what I refer to as a "resonant trap", or a dead space where the ZP Flux is forced by the inertia of the moving electrons to flow in the same direction as the path of the current.
This may be just BS, as I am using my mental chalkboard to envision the event, but that is what I am perceiving as what is happening. Your thoughts on this are welcomed.
Paul Andrulis
Although you are thinking in the right territory, I avoid quantum mechanics and string theory like the plague. It's a personal preference thing, I prefer my science to deal with reversible processes, not theology and philosophy  ;D
I only mention Quantum Electron tunnelling, as that is the name modern science has given to simple density shifts.
Despite this I do like how your thinking (even if it is limited to a finite range, with TDM I can show infinite scale  versions of what you are addressing, I do not mean any disrespect by this, it's just putting into perspective classical physics interpretation when compared to the real scale of things) however it's still good to see others pushing the boundaries of what a singular finite universe can define.
Go have read of this thread http://www.overunity.com/index.php/topic,2816.0.html
Then have think of the wording. Try to break out of the String theory and Quantum mechanics terminology (it's just people with blinkers on trying to describe what's on the other side of the horizon without defining anything that can be measured)
Imagine you two frequencies as being seconds on the hands of two old watches. When you are relative to each scale of each watch, you see each second tick by. But as an external observer you can see for every two ticks of the larger scale watch the smaller watch ticks just second. However it is the smaller watches second hand that is the faster of the the two. As technically it is tunnelling through space time to every second tick of the larger one. So time slows down for it when compared to the larger scale of the bigger watch.
It's all about what you are relative to. As to what you can observe and measure. Classical physics forgets this and tries to describe both watches interaction yet describes no method to allow this interactions to be compared.
Putting it simply classical physics stops at zero,  Classical Physics + TDM defines infinite possible relative scale zero points.
One is finite, the other is infinite possibilities of that finite range.
Now you know why I detest String Theory and Quantum Physics. I have no need for the vague answers they produce ;D
Although essentially in certain parts we are saying exactly the same thing, your is the description of a tear drop, where as mine encompasses an infinite ocean.
Which is the same as saying you are not wrong, I just use a bigger model for the purposes of a more defined description.
I mention all this too you, as I can see real genius in the way you are thinking, you just need a good enough model to use to describe what you are visualising.
Despite what people who adhere blindly to letter of predefined finite classical physics will tell you. There is no right or wrong when you cross the zero point, only the probable and less probable with current levels of understanding.
acerzw
Hi,
    Roberto & Otto you guy's still around, I know you went on vacation Otto, Kinda quiet around here without you, hows it going?
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
acerzw
wattsup
@ otto (or all)
I hope things are well and that ECD efforts are moving forward.
I have a question if possible.
I saw this device on ebay. Was too late to grab it but please take a look and give me your comment on suitability to be used on my ECD testing.
It says high voltage 100K volts but very small amperage. Does this mean very fast voltage speed but fine thread like current with pulsing up to 69 pps.
What I am thinking is the 12 volts DC with 4-6 amps is not the answer. I think what is required is power that has the same speed as the frequency range. 12 vdc is too slow compared to the frenquencies that are too fast from my freqency generator. I think matching these both is the key. It's not only the frequency. Power type is the key also.
Tesla liked high voltage. Speed creates movement, movement creates field, field creates power. Frequency/resonance can then concentrate or expand the power.
Here is the link. It is a very simple component.
http://cgi.ebay.ca/High-Voltage-Pulse-Module-DC-to-DC-6vdc-to-100KVDC-LQQK_W0QQitemZ150150308360QQihZ005QQcategoryZ11737QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Warlock Weary
Bull Or ??
THIS UNIT MAKES APPROXIMATELY
120VOLT 4MAMP
http://www.ncbookz.com/
OUR FAMOUS INVENTION
WE ARE GIVING THIS TO THE WORLD FOR  PRACTICALLY FREE BELOW
IF YOU WANT TO BUY THIS FREE ENERGY SET OF PLANS, JUST FOLLOW THE GOOGLE CHECK OUT RIGHT HERE. I WOULD LIKE TO SAY THIS, I HAVE DELAYED MY EXPERIMENTING WITH THIS UNIT BECAUSE I KNOW IT WORKS BUT I CAN BUILD THIS IN MY SPARE TIME THE AVERAGE TURN AROUND TIME IS 3-4 WEEKS. TO BUY THE WHOLE UNIT BUILT FROM SCRATCH IT IS $295.00(EMAIL ME FOR DETAILS) BUT THE PLANS ARE HERE IF YOU WANT TO TRY YOURSELF. THANKS AGAIN, I AM JUST PAYING FOR THE SERVER COST AND ALSO EBAY COST. I HOPE EVERYONE GETS OFF GRID SOON SO WE DON'T SUPPORT THE SAVAGES WHO ARE MAKING MILLIONS THE COST FOR PLAN IS  $52.00
FREE ENERGY DEVICE     $52.00  includes shipping
HERE IS THE CHECKOUT FOR THE ACTUAL BUILD ($295.00)
Sent a email will see if he responds :/
