Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
gn0stik
Quote from: z_p_e on June 18, 2007, 01:57:01 PM
Thanks Rich...got those.
Inductance is the most important measurement I need however, and failing that, I can calculate approximate inductance from the coil dimensions I mentioned.
Darren
When I get time I'll check the resistance and inductance of both coils. I gave resistence for both coils together, didn't think to do it separately.
Also, I've often though, "couldn't you have just counted turns when you wound?", And yet, I did not. Sorry about that, so no turn count. It's not too many though, we're not talking thousands, couple hundred on primary, max, little better than double that on the secondary.
Not that that helps.
Rich
z_p_e
OK, I'd appreciate that, and it would be helpful for the project as a whole to see how close everyone is with their coils.
I may wind my own bifilar too (to your length and guage specs) for comparison and further analysis if need be.
Darren
devilzangel
ya .. i was wondering the same .. it goes w/ what many of you have been saying ..
i mentioned this in the previous thread - http://www.overunity.com/index.php/topic,2235.msg33932.html#msg33932  ;) :D
it could be the ion effect, superconduction . etc who knows ... BUT i am inclined to think that we are using a "brute force" approach to accessing this advanced energy .. if we extract this energy correctly, the device should actually be cool to the touch (again a guess).. .. many things could cancel the flux .. certain coil configs can do that too .. mobius, etc. I wonder how using crystals or fiber optics will play a role in advanced Free Energy extraction.
i am currently working on really looking at the SM vids frame by frame to see if i can make decent drawings of the devices .. they show some very good close ups of the 15" coil .. but i am also looking at the open frame TPU vids also to look at the coil configs and wiring ..
(something i found interesting .. if u look at the very OLD one, where he is in a workshop showing the small device flipping 180 degrees; if u look at the frame when he is flipping the device, u can see a metallic central vertical core. .. like a tesla coil)
ps .. i cant download the vid from the link or other vid downloaders .. it keeps erroring .. may be a prob on my end.
devilzangel
Quote from: mrd10 on June 18, 2007, 10:43:25 AM
Folks it just occurered to me, that SM used to talk about Vacuum tubes right, well how do they function, they produce heat, same thing what Otto and Roberto have found out,
what if this is what cancels the magnetic flux and speeds up our electrons, same as what happens ina vacuum tube.
what about the imploding tv set, if the coil malfunctioned or there was heat involved, which set things in motion, wow.........................
refer to the heat magnet motor, you bring heat next to iron, with magnetic field near it like a magnet, and what happens, it looses it magnetism, so im thinking along those lines:-http://scitoys.com/scitoys/scitoys/magnets/magnets.html
Also we know that these things produced heat, so there's the other clue.
Kind Rgds,
Dom
dutchy1966
Kind Rgds,
Dom
Dom hi,
You might have a good point there. It might be the very reason why SM was never able to solve the heat problem. I just wonder if this is the case why it already works at design maximum after a few seconds.....hardly time to heat up if it is that important.
Robert
dutchy1966
Quote from: c0mster on June 18, 2007, 09:47:00 AM
If you keep cooking your mosfets try the IRF730 they seem to perform well for me.
I will do some more test later in the week to verify the seed.
Cam
Hi Cam,
I asked Otto a few days ago about the IRF730 as it has a even faster rise time then the IRF840 (10 ns against 23 ns), but according to him the IRF730 doesn't work properly for this setup. Input capacitance had something to do with it he said.
regards,
Robert
