Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 255 Guests are viewing this topic.
c0mster
Bruce_TPU
Well tonight was fun...not! :)
Spent much time rewinding my control coils onto the 6" loop and off of the spools like I had them.  I am sure Rich can relate.  LOL
My partner spent a great deal of time soldering small little pins to the IRF7307 drivers.  They are near microscopic and VERY difficult to work with.  This is why several pages back Roberto approved a MIC for the driver that has pins and is easier to wire.
@ Stefan
http://www.overunity.com/index.php/topic,2535.msg35456.html#msg35456
at this post, reply #236 Roberto asked for the schematic of the MIC4426 driver to be placed in the FAQ.  I am sure you overlooked it, because it isn't there yet.  This driver will save hours off of the build time compared to the IRF 7307!  LOL  My partner would agree! :)  Thank you!
Cheers,
Bruce
z_p_e
I was going to wind a coil, but I don't have the #24 wire, so I decided to try and calculate the inductances.
What I came up with:
Primary: 15.5uH, 0.36 Ohms, [165.32 inches of #24 wire], 90 turns
Secondary: 107.8uH, 2.28 Ohms, [413.28 inches of #28 wire], 248 turns
I used a coil length of 1", and a starting bobbin diameter of 0.5".
Hopefully a few people will add their specs for comparison.
Darren
Thaelin
   Here is the driver file. Covers the 26 and 27. I was looking for this one and Norvac Elec. here has no listing for it. Go figure.
sugra
Jdo300
Hello All,
I'm finally back from my weekend trip and thought I would take the time to draw up the the circuit diagram for my control circuit.
It uses the mic4427 MOSFET drivers for the IRF840 MOSFETs. For those of you wondering where to order them, they can be purchased inexpensively from this website here:
http://www.arrow.com/
Search for mic4427BN. That is the correct chip.
I am currently modifying my control circuit to output extremely small duty cycle square waves (500 ns pulse width) to conserve input power. My firm view is that we only want to put in enough current to load the coil inductance and no more. Any extra input will simply be wasted. The attached circuit diagram does not include the ICs I will be using for the pulse width control but I will be using the 74HC423N chip. It is a Dual retriggerable monostable multivibrator which, using a resistor and capacitor allows you to vary the output pulse width from a minimum of 75ns and up. The mic4427NB drivers need a minimum 500ns pulse width to turn on and off properly.
As soon as I have finished the modifications to the control circuit, I will post an updated circuit diagram.
The board I have currently runs on a single 9V battery and the input frequencies are controlled by three separate battery-powered function generators, which I bought from here:
http://www.electronickits.com/kit/complete/meas/fg500k.htm
They have a range of 1Hz to 1MHz. Above, 500k, the square wave output really breaks down but since the FET drivers are comparator driven, it won't affect the switching of the MOSFETs.
That should be all you need to make this circuit. If you want to use 555 timers, make sure that you put some capacitors in parallel with the power supply inputs to the timer chips because the FET drivers draw a lot of power when they are running. If you have any problems, PM me and I'll see what I can do to help you.
God Bless,
Jason O
