Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
bowser03
Notice on the Chancey Britain Patent, he is using a copper tube which  is elevated.  Isn't that something, he has formed a glass capacitor too.
Gustav22
We know that a few months ago Otto hit an ideal setup of his ECD.
No load was attached at the time. The device ran away and the weakest parts self-destroyed.
Why do we not have success in replicating this?
Can none of the replicators properly tune their setups?
Why does it not work again?
What is the difference between Otto's successful setup and the replications?
Well, I guess all ECD replicators attach light bulbs as loads.
Why does the ECD not run away with a lightbulb attached?
As far as I understand all wire lengths of a good ECD setup have certain ratios so that resonance is facilitated and the whole setup is in tune.
But what about the load assembly (light bulb plus connection leads)?
Should that not be in tune with the rest?
What if it were?
So here my suggestion:
For testing, it may be a good idea to choose proper 'in-tune' wire lengths to attach the load. I suggest ca. 80 cm (31.4") (i.e. same length as the collector) or (sub-)harmonic ratios of this length.
money for rope
giantkiller
Quote from: tim_crouse on July 22, 2007, 12:04:26 AM
Is or has anyone release any drawings of the successful prototype?
I have access to a lab full of equipment, a machine shop, and Labview
If I could assist you folks to get some things some things verified let me know.
Best Regards
Tim C.
@Tim Crouse,
I can't speak for the others because I am not sure how many ECD builders there are but here is a link to my current progress. I followed Roberto's ECD document and been following and replicating Otto's designs and configurations. The Lords of the ring starts with that. This link puts you in my SM progress at the ECD stage progress.
http://www.overunity.com/index.php/topic,1872.msg39888.html#msg39888
But as a caveat, I do not not want to detract from this or other threads. There is valid information everywhere.
My current and unposted delima is I toasted a fet trying out a suggested experiment. I don't want to waste thread space on this.
--giantkiller. Enjoy.
13thHouR
Quote from: shuzammy on June 13, 2007, 06:23:15 AM
Quote from: otto on June 13, 2007, 05:40:50 AMSM told us that there are a lot of ways to built a good TPU. So, in a very short time, I suppose, there will be TPUs like the open one with the controlls wound all over the collector and a few other types.  I only wanted to give the basic setup that I have. Its on you to find other possibilities to built a good TPU. Otto
With that in mind I wonder if there would be any merit in considering how a TPU may be wound in a Tensor or Caduceus Coil manner.
"This coil has repeatedly been found to violate established laws of electrodynamics and hertzian wave theory when high frequency is injected into it."
"This apparatus has zero impedance - unlike an ordinary coil."
"It has infinite resonance - unlike an ordinary coil which will resonate chiefly at its natural fundamental frequency and weakly on the 2nd or 3rd harmonic, the Tensor coil is capable of resonating strongly on any number of frequencies randomly spaced in the spectrum."
"A few investigators have also reported unexpected bizarre inertial effects (READ: "gyroscopic effects"?) in conjunction with these coils."
Perhaps if one modeled a TPU after the omni-resonant antenna-like features of human DNA (caduceus style), one "may" inherently solve the problem of TPU super nova ("spontanious combustion")... ?
- http://uncletaz.com/library/scimath/cadcoil.html
- http://www.keelynet.com/time/cadsmith.htm
- http://jlnlabs.imars.com/spgen/
You have hit the nail on the head, the double helix is the way to go, however you must remember that you must use much lower voltage/amps on your feed as this will reach saturation point much quicker.
To overcome this you have to change it to crystal filament double helix. Quartz can withstand much higher temperature without failure and as some of you will find it creates some very interesting side band harmonics as well as not requiring an input frequency. As the quartz is naturally resonant when power is applied across it.
If using a triple core double helix crystal filament set up, the desired frequencies are 7, 14 and 21 Khz. Please do remember about synchronisation. The observed sweet spots with combined frequencies on previous experiments was to do with the fact that at certain frequency combinations you where creating a new side band frequency. This 3 note harmonic is important. When using quartz it is more to do with the 3 separate start-up up feeds, to get desired synchronisation.
You need very accurate timers which lets you phase the start sync of each frequency.
I will warn you in advance the initial EMP off this can be quite intense. do not and I mean DO NOT! do this within 1/2 mile of anybody with a pacemaker. If you do not have adequate shielding
according to how many time you fold the double helix back on itself will proportionately double its resistance for each fold and also double its energy density level.
Do not attempt more than 10 fold backs, as the Ion saturation level will be enough to levitate any object within it's vicinity. a cool effect, but really screws with diagnostic equipment.
Another thing you want to look at is Prof.Dr Gunter Nimtz's work on quantum electron tunnelling.
You may begin to understand the importance of a moderator between the field coils and the output coils. Some of you may have already noticed that the type of the coating on the coil wire does alter the outcome. Exploit this.
Have look here, I am in the process of making TDM public domain, now that science has caught up, I can begin to make people aware that over unity is nothing more than a term created by blinkered science, (how many people here know that the laws of thermodynamics are based upon a philosophical argument, not science?) in fact classical physics does predict the observed effects. Einstein knew the dangers of this, this is part of the reason why he was so reluctant to admit his theories predicted black holes.
http://www.overunity.com/index.php/topic,2816.new.html#new
It will take me while to write it all up again. So please be patient.
That helps explain some of what you are exploiting, note:  that it does not require the laws of physics to be rewritten. In fact it endorses them, but unusually it also allows so called over unity to be fact of physics.
btw there are other combined sweet spot frequencies   3, 7, 9,11,13, 33 and 39Khz  (Don't even think about quoting masonic conspiracy to me  ;D )  Remember when using these frequencies with standard generators, to adjust the phase of the synchronisation of each of them to achieve the required side band harmonics.
Edit: After some soul searching I decided to add this part.
These TPU devices are working on two fronts,
1. Is a frequency induced Electromotive force
2. The other is as some have already mentioned. Gravity.  This is the gyroscopic events that has been felt during tests.
As I progress my post on the TDM thread I will explain what gravity is and how to manipulate it.
One very big word of warning, I really mean this as a WARNING! be very careful of that gyroscopic effect, if the gravitational field exceeds a saturation per volume that is greater than anything on the earth, the object will launch at escape velocity as it will be attracted to the next heaviest object in the solar system.
If you exceed ZPE frequency density of this point in the space time continuum, it will assume the relative density proportionate to its Gravitiational compression level. Plain English you will fold space time.
Some of you may think this is a little far out and too crazy to be true, yet with the use of simple photon compression target Prof.Dr Gunter Nimtz has been able to successfully transfer Mozart 40 from one location to another at several times the velocity of light. I mention this as it is a publicly available experiment. Although the smoothing of Quantum wave packets may not be arguably transfer of information in the classical physics term. There is no avoiding that a data stream was propagated over specific distance by non subluminal means (Faster than light) using a moderator, 'the target'.
Super God
I think you're onto something.  In ethernet wiring, the receive and transmit pairs are twisted much like a caduceus coil so that it cancels out noise in the pair.  Weird.
>9000
