Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
otto
Hello all,
this morning I pulsed finally my deflection coils from a TV. What a magnetic field!!!! At low frequencies I saw a really big magnetic field over and inside this deflection coils.
I was pulsing this coils with square waves and saw only sine waves. On top of this sine waves I saw fine, nice kicks. Hmmmm......I will ask my friend to give me another deflection system so I can see whats inside this coils. I know there should be iron....
A lot of years ago I was a TV repairman. In the times when the tubes are used but I never looked closer to the deflection coils in the sense to look inside them. Now its the right time to do so.
As I expect iron inside this coils it would be interesting to remove this iron and then pulse the coils. They are wound in a special way.....have 4 wires for a connection...pulsing them I dont see any current consumed from the power supply on the MOST frequencies. OK, dont hang me. I had NOT much time to make tests. More, tomorrow, I hope.
Otto
jack81
Well...I'm not actually replicating and/or testing (but I'm searching desperately a cheap&good oscilloscope  :'( ), I'm reading and following the various tests Otto is doing. I see lots of excitement in many of Otto's statements. These are statements of a pioneer which allow me to deduce two types of hypothesis:
- he is absolutely C R A Z Y
OR
- the TPU is working
O.K., I've seen the famous Steven Mark videos. O.K., many of you are right when they are saying that Otto's TPU is not self-powering. But I mean - I don't care about that...let's power it from a solar cell and for me it's more than fine. Output greater than input - greeeeeat!
For me it's quite normal that a human being not always delivers accurate measurements and exact details - not in this phase of testing and with this things going on. He is doing experiments on borderlands of physics - and beyond them. There are happening things we can't even describe - far away from UNERSTANDING them. I can imagine the wild chaos in his laboratory. (If I had a full energy conversion with a TPU, I would run for miles shouting and laughing like mad.)
Hot (btw: rensseek, you are damn right!  ;) ) or cold...this are subjective comments, but we need them too.
It's time to throw away a bit of the good-old "black/white" thinking of normal science, that's what I've had to learn also in my professional area (which is psychology). Alright, we must do testing in a scientific matter (Popper etc.  ;D ) but let's share results and comments with a bit less aggressive "energy".
acerzw
@jack
Its great to see your enthusiasm, you are probably right about Otto's lab and definitely right about science.
In summary I think Otto is crazy, but then most of us on here are, otherwise we would believe all the conventional science crap about all this being impossible.
I do not believe Otto has achieved more energy out than in at the moment, however, people with enthusiasm who build and keep building even after a failure or two will definitely achieve their goal of OU eventually... enthusiasm, motivation, determination to win, and pure bloody minded stubbornness will get you there.
Acerzw  ;)
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
leeroyjenkinsii
@ Grumpy
@ Motorcoach1
Are you guys saying you've built the LMD (Longitudinal Magneto-Dielectric) line as seen on Naudin's site?  It seems like you are saying you've built it and it does indeed result in more energy out than you personally put in.
Dude if that's the case then I gotta try it!!  I mean who the hell cares if it's a ring, a loop, a cheerio, or a toothpick.  If this works, and you get more energy out than in, then that's it.
Am I missing something?
Thanks a lot.
singerxyz
Just something to put out there-
I was playing with a software based function generator, sending various frequencies through a coil wrapped around a ring magnet, and thought to record the frequencies as a .AIFF (mac version of .WAV) file, and it worked. playing the audio file still showed the same effect on flux.
So you can use a tiny portable mp3 player instead of a giant function generator. If you need more amperage, use a small battery powered speaker like a computer speaker or tiny 9V guitar amp and disconnect the speaker and use the speaker wires as the output to the coil.
