Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
acerzw
Singerxyz
Thanks for the confirmation that this works, I had posted on another thread regarding this possibility, it is good to hear that it works, it will simplify experimenting a great deal.
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
otto
Hello all,
yes, Im a little crazy man because Im working all the time on my various coils, TPUs...but its soooo interesting!!!
A little example:
this morning I connected my deflection system and pulsed this coils. Result: at 22V and arround 2 - 2,5A input from the power supply I almost lighted a 100W bulb. NOOOO!!!! F..k overunity and COP better than 1 and all this stuff. I dont make any claimes about power input and output. My claim is that Im only playing with this deflection coils. And my claim is when I have the brightest light that a magnet holded with my fingers inside the coils I can feel a vibration of the 3 frequencies mixed together (5 - 6 kHZ??). As in this deflection coils are iron cores the used frequency mix is at frequencies between 1 and 10 kHz. My next step is to remove, if possible, the iron cores and then to pulse this coils at a much higher frequency mix and then to see how it works.
At low frequencies I saw the magnet spinning over this coils and that means I have a tornado. Because of the iron cores this tornado is only a 3rd category one but without the iron.....
I can imagine that our master did the same because the kicks are soooo nice....with this coils the newbies could easily learn a lot about coils. The kicks with this setup have not soooo much hash and its easy to see what happens when you change the frequencies.
You want to know why Im using a Rodin coil collector and now a deflection system?? Its because my Mobius collector didnt work as I wished and now Im looking for a solution why are various coils better then my original setup. If I would be so crazy to build a little Mobius and hang it into this biiiiig magnetic field inside my deflection coils.....dont worry, I am!!!
Almost forgot: the height of the outher coils of this deflection systen is 44mm. I already have another deflection system, from another type of TV. Height of the outher coils is 44mm. Height of the 6" TPU and I think of the 15" TPU is 44mm!!!  HA!!! NICE!!!
Tomorrow I hope to wright about my results without iron cores.
Otto
ronotte
Hi all,
Hello Otto, WELL DONE.
Who says that you are crazy? Actually you are a Vulcano! Deflection coil test should have been the first task to do from the inception of this thread...remember the many stories about!... but nobody, me included, worried enought to start the possible run-away replication.
So I plaude about this new corner to discover. And I strongly suggest to slide into the deflection coil a standard Mobius loop and see what will happen. From some point of view the TV deflection coil may be used for it's task: to focalize the particles and accelerate them as well ...who knows?
For my side as I've completed the Caduceus coil tests, I'll open a TV set I've, extract the deflection coil and pulse it in the standard Mobius setup. I'll report here the results.
Ciao
Roberto
otto
Hello all,
@Roberto
what I can for sure say is that there is a huge magnetic field inside the deflection coils.
Im pulsing them with square waves and have, without a load connected, sine waves with a kick sitting on top of this sines. I like this waves. With the 100W bulb connected I have only kicks. This kicks are only positive.
Now Im looking for a 3rd deflection system from a biiig TV. Its a 72cm diameter screen. There must be a much bigger magnetic field, a bigger diameter of the coils, everything bigger. The output????HA!!! BIGGER!!!
As posted before, 1. iron out of the deflection coils so I can pulse them with high frequencies and 2. Mobius INSIDE this deflection coils and see whats going on. I think that after this tests I can really fix my scope again! Its just a feeling.
If you Roberto or anybody else will play with this coils please, be extremly carefull.  My feeling is that we are working on a very dangerous "discovery".
Otto
jack81
Wait...
@acerzw & singerxyz:
are you shure that soundcards and/or final stages of audio amplifiers do arrive at the required frquencies?! If this thing works without any function generator but with an ordinary soundcard and heterodyning that would be great! With "Adobe Audition" I can generate just all the waveforms I want!
