Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 166 Guests are viewing this topic.
ronotte
Hello Otto,
wonderful signal, really I never have seen such situation: all the sine waves have their own peak sitting on top and...if I have well understood the sine amplitude should be about 200V ptp  (please tell us where the 0 line reference is on the screen and time time scale).
To summarize the typical Yoke coil does have 2 Horizonthal coils and 2 Vertical coils. You have connected two (hor. or vert. coils) coils in series and than to the load, while pulsing the other two (in series as well?) with the 3 freq mix and LEAVING the + connection to the PS FREE, am I right?
Does it means that you have NO connection to PS?....are you pulsing without the Mosfets?.....Perhaps it would be better if you take a little time and draw a quick schematic for us....thanks.
Roberto
otto
Hello all,
@Roberto,
firs I wrighted sometihing different and the I saw that I have 1 of my deflection systems here on my workplace.
The load, the 24V from PS and the pulses are connecterd to the inner coils. This coils are in PARALEL connected and there is NO iron.
The outer coils are connected in series and are wound arround the iron core.
This is the reason I could pulse my inner coils this morning with a high frequency: I disconnected the outer coils and the result in brightness was the same.This could mean that my inner coils are good and I have to make "only" a Mobius instead of the outer coils and then....only God knows.
Since Im working with this coils Im thinking of deleting my last posts because I was a few times in a f...g situation: I clearly could and can hear the MOSFETs switching. And this switching speeding up to a crazy speed. As Im a newbie with this coils it would be much better first to explore this coils and then post the results but....hmmmm....Im sharing my results!!!
Be carefull. This coils are very dangerous. HA! I said it in a veeery nice way.
On Monday, if I stay allive I will post more. Weekend!!!!
Otto
ronotte
Hi all
@Otto
It seems that you have got a completely new setup, I wonder what would happen with the Mobius loop as collector. I cant wait to hear your results.
For my side, I must say that my wife , some time ag?, without asking me put to the waste 2 old TV-set and 2 old monitors I once had...so now I'm looking for old TV-set from friends of mine....until I found them I'll continue the tests with Caduceus coil as I must pulse it with 2 - 3 freq and Mobius of course. Until now I did it with only one freq and obtained almost COP=1 at a power level of about 20W  (minimal setup: just the lamp connected on a single wire trough the coil).
Roberto
otto
Hello all,
@Roberto,
we need a feedback, as you know. You should have a double Mobius as collectors. One Mobius connect to the bulb and NOTHING else and the other Mobius you have to connect to the controls....only in this way you have a setup that can give you a possibilitiy to feed back a tini part of the output back to the input. It works, I tried it.
As I have a lot to do this weekend, as always, it will be a f...g one. The problem is that the outer 2 coils have the wires wound arround the iron cores and that this wires are not strong enough. I have to remove this wires, count the number of windings, again wind this coils with a Mobius inside.....well, I wanted a TPU!! and so I have to earn it!! HA!! I hope this weekend will NOT be lost in a wrong way to build a TPU.
Its clear that when finished, I have to "translate" my work into a TPU in the sence our master told us but for now.....Im learnig.
Otto
ronotte
Hi all,
@Otto,
we two have both a NICE week-end of work (read:fun) to do. Well so many ideas it's right so that I like. I do hope that other will soon join us in this context in order to share the results & propose new themes to follow.
Please, if you get in touch with Shad, give him my best regards and tell him I'm studying deeply the Igina book/reports!  Veeery interesting!
Roberto
