pulse motor Working video and info
Started by adam flow nemo, June 15, 2007, 02:03:22 PM
Ren
nice. top setup. Love the positioning of gauges.
So let me see if i have this right. There is power (small trickle) flowing constantly through the second winding?
Or does the magnet trigger resistance or such in the second winding and when this reaches a certain level the transistor switches on?
Im interested in how you time it, especially since there is a north and south pole on your rotor yet yo tell it to only fire on the north.
Does the magnet passing by create the voltage which sets off the transistor when it reaches a certain point?
That may not make much sense, I'll re-word it if you like.
Nastrand2000
Ren,
I have a diode on the trigger coil, so when the north face of the magnet passes by the coil it creates enough voltage to open the transistor. The diode only allows one direction of flow, so when the south magnet passes nothing happens. When the transistor opens, current is allowed to flow through the driving coil. You asked if there is a constant trickle, the answer is no. The moving magnets create the voltage necessary to open the transistor. So the only current you see on the gauges is what is going to the driving coil. Hope that helps.
Jason
tropes
Jason
While you're lurking with a Foster in hand, give this some thought: I wrapped a coil around each piston in my Sotropa Motor. When I complete my 4 piston motor (just about finished the crankshaft) I would like to add this free 3 volts in series to the BEMF. You think?
I uploaded the video to the bottom of this page
http://www.theowlnest.com/opm.html
Peter
Nastrand2000
Tropes,
Are you looking to nullify the BEMF using this captured voltage? By capturing this voltage and storing it you will cause BEMF in your generator coils.
Maybe I'm not seeing the question correctly. Please tell me a little more. The 3 volts can be captured into a cap and dumped into what you see fit. You may want to check this video out.
http://www.youtube.com/watch?v=9_rvJQb2SDY  this is from tao in another thread.
Jason
Nastrand2000
