pulse motor Working video and info
Started by adam flow nemo, June 15, 2007, 02:03:22 PM
Nastrand2000
However, I'm not saying this motor is worthless. Quite the contrary, this is the first step to building greater things. The motor has alot of torque for the power input. If I was to run my whimhurst machine with this motor, the output would be around 40,000 volts. The amperage would be small, but I think it would be more efficient. Right now I am recapturing about 30 percent of the power with no drag on the motor.
My end game plan is to be able to split water with voltage alone. And this takes about 1,000,000 volts, but there is almost no current draw to do it. The the machine will run itself plus other things hooked to it.
Jason
b0rg13
ok then ...it needs to be built with power.....is there some kind of home made gen or something common that can be hooked up to it..must be something it can turn easy...like an old bike dynamo type thingy.. ?.
.. so two basic problems here , motor grunt useing no power or next to none
and then a gen that can spin very easy and puts out a good punch!...
if you want to get out of the rat race,you have to let go of the cheese.
Nastrand2000
Now your getting at the crux of the problem with overunity (output more then input). The problem is, that its not very easy to rewrite the laws of physics and chemistry. But we all work towards that goal.
Jason
Nastrand2000
here is the latest video. The motor is running at 2 volts at 15 milliamp with the new coil. Output is around 80 volts. http://www.youtube.com/watch?v=MssgnWZRCbI&mode=user&search=
Jason
Nastrand2000
Ive decided to start running this motor at 3 volts ( easy to reproduce, 2 double A batteries). This should make replication for others easier.
Jason
