pulse motor Working video and info
Started by adam flow nemo, June 15, 2007, 02:03:22 PM
Thaelin
@ REN:
   Nice job on the motor. Have one of thoes in the back room too.
@ All:
   Just a tid bit for you all. When deciding on your coils, you can wind them taylored to your situation. Ohms law will give you the size for the situation. Just shuffle it around to solve for resistance and that will dictate the size of coil. Example  12v and 1 amp comes out to be
   12/1=12 or coil resistance of 12 ohms.  That will be if you leave the coil "on" all the time but we dont in this type of motor. Then run it as to almost equal the force of the magnet.
@ Nastrand
   Will PM you and we will talk some
tropes
Quote from: Ren on September 13, 2007, 01:40:53 AM
here  is a video I made. Making progress!
http://www.youtube.com/watch?v=qStF_wbz97Y
Hey Ren
Good to see the progress. I'm still putting together a 4 piston Sotropa Motor and have plans for a rotary motor with 4 coils between two rotors. I will be gone for awhile due to surgery next week but when I get back I will share the rotary motor plans. Keep having fun.
Peter
BTW this is a good site for someone just starting to build
http://www.simplemotor.com/
Ren
I hooked the collector up to the bridge as well and almost doubled my output. The second coils dont fire but are still sending back significant amounts of high voltage spike. I might try hooking them up to fire as well and see if that gives a better result. Here is a schematic, excuse the quality please, its the first Ive ever drawn!
Hopefully someone can benefit from it, or even better still, hopefully someone can make a comment or suggestion.
Nastrand2000
One thing I do per night is figure out how much wattage I want the motor to consume during its normal operation. And I personally never go over 1 watt consumption for my motors. Then I try to tune the motor for the most output I can get for the input I am giving it. This has taught me alot about different efficiencies at different inputs. It helps me to make one goal per night and see the outcomes.
Jason
Nastrand2000
Ren,
Very good schematic, It is very easy to see how you are running the motor.
Jason
