pulse motor Working video and info
Started by adam flow nemo, June 15, 2007, 02:03:22 PM
Ren
what voltage is hitting your battery jase? What sort of time frame to charge?
Nastrand2000
Ren,
400 volt spikes according to the oscilloscope hitting the battery. Time to charge a 9 volt (duracell that is not rechargeable) is around 4 hours. End voltage is around 11 volts.
Jason
Nastrand2000
Please remember that I am using a variable power supply to run this motor and not another battery. The power supply is plugged into the wall. all I'm trying to figure out is the best way to create a circuit for recharging a battery before I use a battery to run this motor.
Jason
Nastrand2000
I suppose I should start charging a a 1.5 farad 24 volt cap (which is a monster cap)  at differing voltages to the motor. This would setup a control that could be verified by other researchers. This seems to be the only way that battery chemistry is not involved. But by removing chemistry from the equation, I think that we might lose an integral piece to the puzzle.
Jason
RunningBare
I got a 2 farad 24 volt, great aint they!
Try charging it up and put it on your motor with no other power source.
Quote from: Nastrand2000 on September 15, 2007, 09:18:15 PM
Jason
