pulse motor Working video and info
Started by adam flow nemo, June 15, 2007, 02:03:22 PM
Nastrand2000
I will answer this tomorrow...sorry i have to go to bed now.  I will redraw the schematic to show you where to recapture the energy.
Jason
tropes
Jason
I have built several pulse motors in the past ( http://www.theowlnest.com/kickbypage.html ) but I have never captured the bemf. I hope to learn from your experience.
Peter
Nastrand2000
I changed the circuit a little bit (i had a wire going to the wrong side or the transistor). But the picture below should help to answer your question I hope.
Jason
tropes
Quote from: Nastrand2000 on September 01, 2007, 03:22:29 PM
Jason
Thanks Jason
I will study it carefully. BTW, are the rotor magnets S or N pole outward or does it matter? What  are the specs of the Capacitor and battery? What is the PN of the transistor?
This diagram is one I got from Konehead.
Nastrand2000
Peter,
My magnets are alternating north south, I'm only using 4 magnets on my current setup. My battery and cap specs change all the time because I'm always switching them around. The caps are anything 2 micro farad to 1 farad, ranging in voltage from 25 to 400 volts. The transistor is a tip3055 (part number 276-2020 from radio shack). But I've found that most npn transistors will work, although each one has its own characteristics.
you can see my motor at http://ymygody.googlepages.com/
Jason
