pulse motor Working video and info
Started by adam flow nemo, June 15, 2007, 02:03:22 PM
Nastrand2000
Yeah the 1 k should be fine, just start at full resistance and work backward. Also make sure the resistor is rated above the power you are using. 12 * 1.6 = 19.2 watts, as long as it is 20 to 25 watts it should be fine.
Jason
Ren
ah ok, thats why it didnt work. rated at .5w lol. So when I get a proper one I should install similar to the way you showed me to install amp meter reading, i.e current flows through? Just after the switch huh.
heres a couple more vids of tests.
http://www.youtube.com/watch?v=y3Ef9SRXp30
http://www.youtube.com/watch?v=2Ey12pkaEPQ
Nastrand2000
yea... always inline with the current. I've burnt alot of components trying figure out how to use them. :P Just trying to save you the trouble of that.
Jason
Nastrand2000
I like the videos....Good work!
Once your figure out the transistor circuit you will be amazed at the difference. make sure to be ready for 1000's of rpms. Just be careful. Good luck
Jason
Ren
I am hanging out for this circuit. Hopefully I can get it sorted soon. The microswitch is overheating and losing speed after about 10 min running.
