pulse motor Working video and info
Started by adam flow nemo, June 15, 2007, 02:03:22 PM
Nastrand2000
I could wind your coils and sell you the magnets at no profit. I dont mind helping other builders. But the price for me to ship there is large, and i dont want to charge you any more then 100$. let me look at some other options. And yes the magnets will be the same as seen in the videos.
Jason
Nastrand2000
there is a ups store by my house. Im going to go talk to them and see the shipping costs, I cant believe that it is the same as online. If it is low enough, I will build the motor for you and send it. This way you can take it apart peace by peace and see how it works. The one thing you cant take apart is the coil. If you try it will ruin it.
Jason
b0rg13
i just found a magnet supply place here in my home town... im going to go have a look right now, ill update shortly.
if they have what i need my only problem will be the coil!.(s).
if you want to get out of the rat race,you have to let go of the cheese.
allcanadian
Hello
I have a question, where does the excess energy come from to charge the 2nd battery? I was looking at the last circuit nastrand2000 posted and Im not getting this.
Ren
borg, try ebay for your magnets as well, there are quite a few dealers. Do a search for neodymium  or ceramic magnets.
If your looking to do a replication I would suggest starting off with a simple bedini SSG circuit. This calls for ceramic magnets around a bicycle rim. They are alot cheaper and give excellent results. Some people argue that they are better that the stronger magnets, and I notice that Bedini uses them over Neo's mostly.
Ive got my hall switched motor crankin now, Its unbelieveable how fast its going. Its drawing about an amp, but this is adjustable by simply changing the position of the switch. I've had it as low as .4 of an amp. I ran it for about half an hour last night and everything remained dead cold, and battery didnt drop any voltage, infact it went up .01 of a volt. As it gets faster amp draw drops till it settles on a spot related to positioning of sensors.
I still need a way to harness this voltage coming off the secondaries. Its up  to 60 volts now on the digital meter. I think whats happening when I hook up my analogue (needle) gauge is the spikes are being earthed because it drops to 5 or 10 volts. Theres definately more than 10 volts coming out though. When I hold the output lines my hands start to go numb with tingling. I will post some schematics and a video in the next couple of days and hopefully some one can help me refine and/or change the setup to benefit from this voltage spikes.
s
