Half TPU
Started by MACEDONIA CD, June 16, 2007, 01:02:07 PM
chrisC
Hey Bruce:
Please don't take this as a disrespect. I'm so confused by your many statements and theory.
This last one is like you''re translating Macedonian to Dutch! (sorry if we have Dutch folks on this forum!)
Cheers
chrisC
Bruce_TPU
Hi Chris,
No, It is a great question!  So let me clarify, because it will help others as well.
My theory 1.3 LOL
In my mind I have broken down the components of SM's TPU as follows:
1.  Operations/function
2.  Solid State controller
3.  Real function of the control wires
Operations/function
For the function, I see frequency signals at fast send off as we have been doing, within the collectors.
As part of that process, I see identical signals (35.705 KHz + 250 KHz or close) with different sources input in opposition to one another.  This sets up two revolving fields as a gyroscope within the Collectors.  This function will create power.  I believe far too much, if we seeking OU can wrap our mind around that.  That brings us to the second part:
This will do the following, as I see it:
1.  Send off the signals fast send off (I believe Roberto has given us a start on this)
2.  Will provide seperate sources for each cluster of 2 or 3 frequencies being sent in opposition.  Based on what BEP has said, It would be only 2 frequencies, because the intermodulation would be the third and would happen within the collectors automatically.
3.  Future controller will have to "modulate" (I think that is the right word.  BEP would know) the frequencies, because they would continue to create new frequencies as BEP on my thread shows and without control, as SM said, it will destroy itself.
4.  Will invert our battery to AC and feed this into the control coils at 7.23 hz.  That brings us to the third part:
Control Wires
Control wires that "control" the flow of electrons by sqeezing them like water to go in just one direction, thus giving us an output of DC and not AC.  This is done by an oscillating AC electromagnet at 7.23 Hz.  Providing a changing field and a strong magnetic wave for minimal power.
As you can see my theory has matured!  LOL   ;)
I hope this helped!
Thank you for your time,
Bruce
giantkiller
Very good.
Now picture in your minds the wave directions of the mag fields expansions. Especially when the BEMF collapses back onto the copper...
http://www.gmi.edu/~drussell/Demos/waves/wavemotion.html
We don't want to leave out any artifact of radiant energy.
--giantkiller.
MACEDONIA CD
HI  MY FRIENDS  IS NOT A TRANSFORMATOR   IS ELEKTROMAGNET   OK  MOVING IS HIGH SPEED   IF YOU WHANT A HELP  HERE I M   TO HELP   OK  THANK TO  EVERYWONE       BY FROM    Macedonia   by
Bruce_TPU
Hello All,
This was PM'd to me from our Macedonian friend.  I agree, either we "test, experiment" with an ac 7.3 Hz electromagnet and/OR tune our collectors to that resonance.
OK  YOU ARE DONT  ANDERSTEND MY  IS LIKE THIS
    OK TKIS  IS NOT A TRANFORMATOR  THIS IS ELEKTROMAGNET  HO  IS APSOLUTLI  IS NOT THE SAME  LIKE ORDONERY TRANSFORMER  OK
    YOU MAKE ONLY  ELEKTROMAGNETIC  NOT WHIT CORE    THEN YOU MAKE   COLECTORS COIL   THEN YOU  MAKE  A OSCILATOR  HO IS  PULSE  THE ELEKTROMANETIC  WHIT HIGH  SPEED   IF YOU R  OSCILATOR  IS VERY HIGH SPEED   THEN YOU GET A  BIG POWER  IN THE OUT  OF THIS COLECTORS OK
   BY
The answer is ONE of the three:
1.  AC electromagnet 7.23 Hz  (reference marco's dancing magnets in youtube for more understanding.
2.  Collectors are tuned to 7.3 Hz ("tuned just off of the frequency of power" located at 7.8 Hz, Shumanns Resonance)
3.  Both 1 & 2 must be done.
What I do know:  The answer will be #1, #2 or #3
Happy, Happy days!  :)
Bruce
