Alberto Molina Martinez patent
Started by syncron, June 21, 2007, 08:53:51 AM
syncron
Hi pegasus,
Here you are the pictures.
As I promised I put here also the patent in pdf format.
In foto 1 you can see the embodiment and behind them my digital osciloscope. In foto 2 you can also see my wave generator.
In "schema.pdf" you see the conection wiring. I made coils of only 8 turns, input and output wire went together as in paint 2. But they should go separately as painted in 3. So I've to repeat the experiment. After that I'll try with changing relative position between input and output coils as shown for example in 4.
If all this not work I'll start with an iron core.
Greetings
syncron
Pegasus
Try to arrange the coils in a toroid shape, to not disperse the magnetic field.
syncron
@pegasus:
The mgnetic flux in the interior of the coil setup (1 mm square and as high as the whole body) will not disperse, and the dispersion out of them is the natural way magnetic field becomes closed.
I thought I'll also try to use this exterior flux with aditional coils.
Can you make a paint of a posible toroidal shape of this setup, please?
Pegasus
Essentially you have to build a S.Mark TPU using the Molina-Martinez principle.....
mkt3920
Nice color pictures of the patent at this website, but I cannot translate the language.  I especially wonder what the last paragraphs on the page say.
http://www.gewo.info/ve/Molina/molina.htm
Kent
