Regeneration and the Toroidal Power Unit
Started by EMdevices, June 21, 2007, 10:34:43 PM
turbo
okay, thanks :) will do.
i have some of the o'l am reciever ferite rod antennas  ;D
I will try that first.
Marco
*i got experiment fever again :D
CTG Labs
Ok everyone, I just got in from work and rigged this up quickly.
Firstly I could not get the bulb to light.  But secondly if we look at the bulb signal we can see 70v spikes across a cold fillament of 373 ohms.
The input current using a Fluke 189 is around 180mA@12v.
However, if instead we insert a 1ohm resistor in series with the battery and use the scope with one channel across the battery and the other across this shunt, we get a whole other story on the current drawn....
D.
dutchy1966
Dave,
Hi, thanx for testing this.
Does it look like your oscillator is running really slow? I see spikes at around every 250 us?
Have you worked out the current drawn according to the shunt measurements?
Robert
btw Is this EM's midified circuit with the pnp?
CTG Labs
Hi Rob,
The oscillator runs around 4Khz.  I used the same PNP circuit as EM except I used a coil I already had from another blocking oscillator.
I have not worked out the current using a full integration, but we can see 30 amp peak surges so I dont see any point in going further, it says it all.
D.
dutchy1966
Yep, I see it now the surges convert to just under 1 amp (20-30 surges would fit one division). Well this can be shelved too.... as i said before it seemed too simple to be true....
Robert
