Regeneration and the Toroidal Power Unit
Started by EMdevices, June 21, 2007, 10:34:43 PM
WaveWatcher
I'll check back when I can. Visitor asking for me.. MIB? wouldn't that be a crack! and expected from a nut as well!
TheOne
its some image from the real device from mark? the quality are good!
Yes its seam to use 4 coils but i dont think they are vertical coil its look more like metal core?
otto
Hello all,
red wires = 4 coils with speaker wires
frame = copper plates
Otto
EMdevices
Images came from different forum postings and I cleaned them up a bit.
Interesting take on the plates Otto.
My take is as follows:Ã,  Ã, IRON LaminationsÃ,
Makes sense, since he is placing a magnet.
Makes sense, since you want to wind coils on an iron core.
Makes sense since it heats up, and in the video, SM touches the device lightly a few times (to check for heat) before he lifts it up off the table.Ã,  Plastic would melt. Copper would not heat up, but iron will, due to hysterisis.Ã,
But, it doesn't have to be that way.Ã,  This is just common sense, but we might need to think in uncommon ways.Ã,  First things first.
My vision is to develop, or evolve a circuit from these images and the concept of regeneration.
I will start with a circuit that has the 4 coils shown and we will debate each wire connection that we will add to the circuit.Ã,  Pros and Cons.Ã, Ã,  A circuit then can be simulated and we can get instant feedback if we are heading in the right direction.
Eventualy we should have something,
EM
P.S.Ã,  I would cation against "reading" too much from the images.Ã,  We don't know what is hiding in every object.Ã,  We can only make reasonable guesses.Ã,  We can look at what's obvious, like it's circular, 4 visible coils, magnets, double stack (for magnetic flux path?Ã,  for support?)Ã,  etc..Ã,
hartiberlin
Hi EM,
many thanks for these very clear pictures.
Now the question is, do we see just red tape beneath the
bigger wires or is it a fine wire copper coil, so is this some
type of transformer ?
We just have too few informations.
SM should come forward and finally tell us
more about his circuit. Otherwise we should stick
to Otto and Roberto?s discoveries and should try these
first as they are much better documented.
Regards, Stefan.
