Regeneration and the Toroidal Power Unit
Started by EMdevices, June 21, 2007, 10:34:43 PM
dutchy1966
Hi EM,
to see id really it is the earths magnetic field that is doing this you could maybe try a few simple things:
1  Are the output pulses direction sensitive. I mean the earths magnetic field has a specific direction, do the outpulse change when you turn the blocking oscillator?
2 can you shield the transformer? does the effect disappear?
Hope this can help to determine if it is the real deal.....
good luck! (and keep us posted.... ;) )
Robert
turbo
no shit  ;D
i have alot of ferrite dude  :)
and again that blocking oscillator....
M.
EMdevices
Here's the spike train, they occur every 100 micro seconds so the frequency is 10000 spikes in one second.
I just hope my math is not way off, or I will "kick" myself all day.Ã,  Ã, Ã,  Ha HaÃ,  :)
Marco, do you have your blocking oscillator working?Ã, Ã,  I'm currious to see what other people get.Ã, Ã,  I must do the resistor test, but even resistors have some lead inductance, hmmmm.Ã,  Ã, Ã,  What I need is a power meter based on THERMAL ENERGY.Ã,  That's what I need.
EM
CTG Labs
Hi EM,
If indeed you do have over 3 watts output, with only 0.6watts input, closing the loop with most of it to spare should not be a problem!  This test will confirm over any other!
If a transformer is connected as the load, with a bridge rectifier and a suitably large cap, you may well be able to loop this unit.
Waiting on more results!
Regards,
Dave.
c0mster
Great Job EM
I hope you can share your setup so I can try to recreate the results as well.
Cam
