Regeneration and the Toroidal Power Unit
Started by EMdevices, June 21, 2007, 10:34:43 PM
I can see 10 windings of the bigger coil wire in this red tape
covered coil.
I ask myself, why some claim that this is a bifilar winding ?
I don?t see 2 wires, just one with 10 windings.
Question is, if beneath this 10 turn coil is there another coil ?
So is this a transformer?
Also is there any white wire inside this coil at 90 degrees going around this
circle shell as the output coil wire ?
Maybe if TPU2_3A is not just a white glare but the white wire from these
loose white output cables, then we know, that this is also the white wire
for the collector coils being taped with black tape onto the outside surface of the shell...
Regards, Stefan.
EMdevices
I'm glad you ask.  :)
Look at the offset.
This would imply to me that it is wider, so it could be the white wire wraped around it, or something else.
I'm leaning in the direction of 2 vertical coils where the magnets are placed.
EM
starcruiser
@EM, the item you labeled "C" looks like a stack of ceramic magnets, the kind you can get from radio shack.
The gray item to the right is curious, looks kind of like a DC motor, maybe a starter?
Carl
turbo
well if you browse with windows picture viewer it looks like there is a white wire wrapped around the magnet but i always was thinking it was reflection of the lamps.
Marco
devilzangel
hey marco, at the back side, u can see that winding .. nice catch.
@ EM:
the fact that he is handling the frame with barehands says that there is no electricity/current flowing through those black frames. (everything seems insulated to the touch)
the "stand/leg (6A and 6B)" material looks like compacted CORK or light wood.
EM .. that protrusion (offset) is an illusion if u r talking about horizontal offset in reference to the black frame. .. it is an OUTward protusion illusion , meaning the "wood/CORK" block is only half or less the width of the width of the flat frames. (i am on a computer that doesnt have photoshop, otherwise i would just label it for u). (looking at it the way it is, the "offset" is simply part of the round frame .. it is not to the side, but looks higher than the "leg" , bc the leg is placed towards the inside, it is not flush with the outside dimensions)
on 6B u can see a black "WEDGE" attached to the "leg" .. that may have some purpose since it is underneath "green" (4B) winding component
the WHITE object from where the 2 outpost wires come (4A) seems to be some sort of consolidator or combiner of the charges. i dont know , heck (it could simply be a battery for all i know, it fits the size)
EM .. since u have this much info .. u may want to start a Modeling project in solidworks, or 3ds max ..
I wish i had time .. it seems we are trying to do the same things (to understand the location, and orientation of things in the black frame tpu, in order to have a solid framework (pun intended) from which start an experiment on.)
devilzangel
