Digital Circuit Diagrams+FETs+Drivers
Started by Earl, June 22, 2007, 02:09:18 PM
Earl
Hi All,
here is a circuit that permits exciting coils with the same frequency, but different phases.
Earl
Hi All,
attached is a spreadsheet for Excel or Open Office that calculates time versus phase offsets.
Regards, Earl
Earl
THE ATTACHED SCEMATIC HAS AN ERROR IN THE INPUT TO THE SECOND STAGE.  PLEASE DELETE IT IF YOU HAVE DOWNLOADED IT.  NEXT POST WILL HAVE CORRECTED AND UPDATED SCHEMATIC.
Hi Bob, hi All,
With reference to kicks_circuit.gif at
http://www.overunity.com/index.php/topic,2607.msg37046.html#msg37046
Please find attached circuit diagram of binary divider with inverted and non-inverted outputs for each stage.
This circuit could be used for both 3-coil and 4-coil setups, although it may be necessary to introduce 120 respectively 90 phasing into the divider chain.  Only experiments will determine whether this phasing is needed or not.
Regards, Earl
Earl
Hi Bob, hi All,
Here is a corrected and expanded schematic that has divide-by-N, where N is even, along with both 0 and 180 degree phasing for each frequency.  In addition, I added an optional variable pulse width circuit.
Bob, if you want to fine tune everything then add two stages of variable pulse width at each ./.2 output.  Use the first pulse width modulator to fine adjust each coil's "firing point" and the second pulse width modulator to fine tune the pulse width for maximum radiant energy.
These settings will not change at lower frequencies, so you will still be able to sweep and watch for sweet spots.  When you get to 5, 10, 20, 30 Mhz the D-FF propagation delays are no longer negligible, so you would have to touch up.
It is still not clear to me what resonance is being chased:  L/C, magnet, magnetic, aetheric, Earth-Sun magnetic or plasma effect, none, or ????????
Maybe it is only an aether perturbation effect with rebound that has no resonance or so high as to be unmeasurable/unobtainable ???
I think all the assembled brain power is slowly closing in on one or more anomolies.
Regards, Earl
Earl
Hi Bob,
here is a further updated schematic.  Does this include all your TPU desires?
Regards, Earl
