Scope shots of clean kicks
Started by bob.rennips, June 26, 2007, 11:07:47 AM
bob.rennips
and there is MORE...
With a bifilar and two pulsers both pulsers set up with diodes you can pulse the electric field. The voltage rises substantially with each pulse. This is not the same effect as step charging a capacitor as in a camara flash. This proves we will be able to rotate this electric only field at high speed.
There are lots of possibilities here. What happens if you can set up a rotating electric field and on top of this field pulse it at 7.8 Hz, the schumann resonance ?  I reckon you'll get some major entrainment of the ionesphere energy happening. BOOM.
This would also explain why it's so hard to control. The schumann resonance changes by +-0.5 hertz over the course of a day. During solar storms the schumann resonance can change very rapidly. You can set it off frequency and as the schumann changes it'll drift by the exact tuned frequency of your device and BOOM! (Another SM tick)
bob.rennips
I think the follow shot is of a diode in the 6 inch tpu.
bob.rennips
 Following a questions from Earl.
The coil is connected: 12volts to diode to coil to diode to mosfet to earth.
The voltage level is frequency dependant.
It hunts up and down as you sweep the frequency so obviously a resonant effect. If you lower the repetition rate to around 100Hz it drops in a decay curve down to about 30V. From 5khz and above it looks to be dead straight even on a x10 mag of the timebase. There is obviously an ongoing leakage of the electric field.
I checked again shorting a coil at 90 degrees to this coil does not extract the energy - so my bad on that point. In a bifilar situation shorting the other coil does extract the energy.
I think at the higher pulse rates this electric field can still be utilised to create a rotating electric field.
Bruce_TPU
Hi Bob.R
Good experiments!  And that is what we need.  especially from those of you with the know how.
Hey, I found this tid bit from Tesla about a rotating magnet field on a toroid.  Is there a way to employ this bit into our experiments?
Plate 3  THE SQUIRREL CAGE ROTOR UNDER THE ACTION OF THE ROTATING FIELD.
The wound stator ring described above can serve to demonstrate Tesla's Egg Experiment.  A sheet of non-metallic material is placed over the windings on the stator ring; a metallic egg is placed on this sheet immediately revolves around its minor axis as soon as the windings are energised from a three-phase supply.  As the speed of the egg increases the egg rises on one end and continues to spin about its major axis, thus maintaining a vertical position without additional support.
Happy Days!  :)
Bruce
Jdo300
Quote from: btentzer on July 01, 2007, 10:18:13 AM
Hi Bob.R
Happy Days!  :)
Bruce
You mean this?
http://www.youtube.com/watch?v=brNBVDCeECg
God Bless,
Jason O
