HHO Implosion Engine Study
Started by IronHead, June 27, 2007, 10:07:12 PM
Robb077
You might consider that the best means of converting the nuclear power of a plasma into work is steam...same as the power plant.
An implosion engine is not designed for gasoline. An implosion engine will implode hho to water and the continous heat will generate a plasma. this will make more steam than any other method. 5 of ironhead's plasma electrolysis devices under pressure could generate 100K btu ...enough to run a 3 KW generator by steam! Enough to take you off the grid and power your car batteries or fuel cells at night. Sell the excess kw to the grid.
just build it!
s_c_engineering
robb.  want to make some drawings and post em up?  im picturing some sort of reaction chamber with the ceramic in the middle.  and water all around it to be boiled.  send this thru a tesla turbine and you got power correct?  no how are you supposed to do this without burning up the ceramic?  cause ive seen the torch punch a hole in ceramic.  post some links to what your talking about if you can.
s_c_engineering
look what i found just now... sure looks like someone took the heads off and slapped on a aluminum block with some sort of hho injection.... hmmmm    http://bwt.jeffotto.com/bwt_catalogue/engine.htm
Robb077
sc-engineering:
When I said "just build it" , I meant no disrespect to our Mr. Ironhead, just watch out for the men in black from NSA. Really, if you had everyone oil free, the tax revenue reduction would force the states into bankruptcy....nuff said.
Ok, you can go over to brownsgas.com and look at the patents....one is on redundant burning of water in a ceramic. You need to get the patent number and go to us patents to see the images.  The brownsgas in fed in and it turns to water until the temperature reaches up to 1500 C, when it turns into a gas and a plasma. You need to turn the browns gas way down or you get a melt down.
Just find a good steam engine if you don't like the quasiturbine. Telsa turbines have not been economically viable.
IronHead
I am not looking for the extreamly complex system to start out here , All I want to see is an engine will turn using the implosion effect . Vacuum is a very powerful  reaction. far more powerful than pressure . And the MIB thing , been there done that I know all about them and how they work. We have ways of dealing with them on Reservation, Indian territory. For the  MIB looking in ,you know what I am talking about.
Today I have had 6 out of 10 consecutive HHO implosions . As the cell heats up  the resonance changes , so this is part of the problem . And high voltage igniting is a must from what I have done today.
I am now moving to the 2 stroke modification concept . This will requirer bearing change and ring change to get started along with  exhaust and intake sealing . I will build a new type of spark plug  / injector combination to feed and fire the engine
This is the donor engine  with generator head  500 watts at 115VAC
