Talking about phase...
Started by bob.rennips, July 01, 2007, 08:16:56 PM
Super God
I've taken pictures of mine, it's all wound and everything, the collectors, bias, and controls.  Just figuring out a good oscillator plan with the tubes I'm going to order eventually (money issues)
>9000
Bruce_TPU
Hi Thaelin and All,
It is $34.95 per core with a minimum order of two.  If you or one of the guys want to go halves, on the two order minimum shoot me an email.  I have went halves with someone already.  ALL core orders must be placed ASAP.  Their next production run is August 8.  If an order is not placed soon, it will not be in this production run.
Core:  T650-52
Micrometals, Inc. Home Office
http://www.micrometals.com/contactus_index.html
Address:  5615 E. La Palma Avenue
Anaheim, CA 92807 USA
Phone:
714-970-9400
Toll Free in US:
1-800-356-5977
Fax:
1-714-970-0400
E-Mail:
sales@micrometals.com
tao
Got my cores from http://alphacoredirect.com/
Which seems to be one of the ONLY easy-to-buy-from-online core manufacturer
A recent core I bought was:
Standard Toroid PN# L40
PN# L40
$11.98 USD
4.870lbs
Epoxy Coated Toroid, Id=2.750", Od=5.250", Ht=1.125", 835 VA Relative Power Handling, 0.345 V/turn @60Hz, 15KG
Shipping was fast too and the core is very well made. They even make O-RING cores ;), and will even do custom cores for you at a very fair price.
starcruiser
Quote from: Super God on July 19, 2007, 10:21:01 AM
Why not try a simple blocking oscillator design using a small torrid from a PC power supply and tap that for your open ended primaries? I recall reading that you can build 2 blocking osc and have one track the other and by adjusting the time constant of one you can create a simple frequency divider which is sync'd.
here a a couple of sites that might be interesting to review.
http://139.134.5.123/tiddler2/c0508/block.htm
http://home.att.net/~pldexnis/CTC2_how_it_works/blocking_oscillator.html
http://www.vias.org/eltransformers/lee_electronic_transformers_11_01.html
http://www.electronic-circuits-diagrams.com/psimages/powersuppliesckt6.shtml
http://www.du.edu/~etuttle/electron/elect37.htm
Regards,
Carl
Thaelin
I am good for one. I will even take the two if I have to. Now just to figure out where to get the wire. I will figure on using #20 enamel for the bias wind. Any pointers on where to get the silver coated #16 at?
That way I will be on the exact page when I fire it up.
The only diff here is I plan to use the tl494 plls. I have yet to ever get 555s to be steady. That should make the controller more stable and run a lot higher in freq. That into opto's into gate drivers and on to the mosfets should do the trick.
Thanks Bob B. for the clarify on the windings.
thaelin
Quote from: btentzer on July 19, 2007, 10:25:03 AM
Hi Thaelin and All,
Core:  T650-52
Phone:
714-970-9400
Toll Free in US:
1-800-356-5977
Fax:
1-714-970-0400
E-Mail:
