Self Charging Leyden
Started by argona369, July 02, 2007, 03:02:23 PM
sm0ky2
"Admittedly, I have, for the sake of the argument, made this statement slightly too strong. There is one exception: If you have a conductor, negatively charged, and the conductor is connected to ground by a metallic wire, then the excess of electrons will bleed away through the wire."  - quoted from Mr. Static page
This is a perfect explaination of the salt-water discharging process they used on the bottles - which coincidently was the only way they found to achieve the resired results as the actual charge was isolated under the dried ink and not subject to dissipation into the air.
argona369
sm0ky2
it is possible, i believe, that oxidation (or a form thereof) could have created an insulating layer on the outside of the metalic ink, which would not be present between the ink and the bottle itself.
sm0ky2
meaning that a charge would have a path of travel between bottle and ink
argona369
