Spinor resonance -- explanation for TPU like devices
Started by MarkSnoswell, July 14, 2007, 09:17:10 PM
MarkSnoswell
This thread discusses a possible explanation for TPU and other devices. It is intended to support and lead directly to rational experimental design.
Time permiting I will modify this first post as an index to valuable material as the threas gets longer.
The ideas I bring to the area come from years of part time experimental and theoretical research. I am well versed in the activities of the "free energy" and skeptic communities visible on the web now and in the past. My contribution is in developing new conceptual models that fit both classical engineering and the potential new phenomena being observed.
I am not interested in theory alone nor abstract concepts and maths. I seek simple conceptual models that can be visualised and used to design new technology. I have a well equiped workshops and do as much experimental work as time permits.
In post 5 & 6 I give an outline of the experimental sequence I will be following when I get time. If you have/are already doing simillar experiments or you plan to follow through the tests I suggest please let me know.
Cheers
Mark
Dr Mark Snoswell
President of the CGSociety  www.CGSociety.org
Publisher www.BallisticPublishing.com
CEO www.cgCharacter.com
Dr Mark Snoswell.
President of the CGSociety www.cgsociety.org
MarkSnoswell
Originally posted at: http://www.overunity.com/index.php/topic,2637.65.html
The three components and frequencies required for "interesting" results corelates with requirments for creating spinors. This is unpublished work so dont bother searching for it -- I would post animations but cant due to the size restrictions for attachments...
A simple spin 1/2 spinor can be constructed from 3 nested (referenced) harmonic oscillations of x, 2x and x frequencies in 3 orthogonal axis. It is possible to make real world circuits that exhibit spinor characteristics. I have sets of 3 orthognal coils that form a passive 3 phase resonator in which positive and negative phase rotation directions are distinguishable independantly of view. I was pleasantly suprised to find that strong resonance can also be achieved by tuning the component coils to x, 2x and x. -- to be absolutly clear these coils sets create passive 3 phase resonators that result in rotational fields and most importantly the two rotation directions are view independantly rocognizable in the same way left and right helices (and positive and negative charge) are distinct. It is also posible to make spin 1/2 neutral spinors in which the field is spinning but with no net view independant rotation -- as in neutrons.
I comment here simply to make the observation that the TPU and other related devices (Aurelano's "Mexican device" and Hollingsheads devices) all appear to embody spinor resonance configurations. No one seems to have noticed this as yet... Regretably the quaternion maths to describe spinors is hardly taught outside the one practical application of 3D rotations in 3D applications. Visualization of quaternion and spinors is even less know -- barely done at all.
I have been working on new vizualizations of spinors and have discovered a diverse range of coil configurations that make sense from the point of creating (or tuning into) spinor resonance but are nonsensical in any other context. I supose I can release one image now -- all of the apparent "coils" in the attached image are actually snapshots of trace lines through 3D space as it is distorted by a radiating spinnor. -- forget any intuition borrowed from simple axial rotation as you look at this image. Spinors work quite differnetly -- the spin direction and axis are indicated by the white arrow in the foreground. If you look closley you will also note that the traces spirall in counterwound fashion.
anyway... a lot of what people are stumbling onto appears to make good sense from the standpoint of spinor resonance which, as you can see, is very different from simple single axis rotational systems.
I also attached a (sorry for the blur) scope trace showing output of a passive 3 phase resonator. The phase separation is not perfect in this shot -- it's very dificult to tune perfectly and reject the background single phase resonance in the component coils. The 3 phase resonance has a Q >10x the Q for single phase resonance of component coils and is very difcult to tune into. If you didn't know it was there it would be extreemly dificult to find.
Dr Mark Snoswell.
MarkSnoswell
Originally posted at http://www.overunity.com/index.php/topic,2637.69.html
In response to questions in a few PM's.
One of my recent activities is as founder and president of the Computer Graphics Society www.CGSociety.org
I have been lurking around this field for a long time. I have rarely posted anywhere before because of the low signal to noise ratio in public forums. I am posting here now because I noticed a good signal to noise ratio and a number of people that are doing real work and thinking.
I have been doing some caerfull experiments in a number of areas for a a number of years. The research and experiments are aimed at understanding what is really happening rather then trying to duplicate others work.
I have visited some very interesting people and groups that are very secretive. Steven Marks TPU is not unique -- it has almost exactly the same behaviour, artifacts, failure modes etc as at least one other groups technology that I have seen.
I have been developing conceptual models for spacetime, particles (spinor waves) and spherical wave interactions etc for some years now. Spinors are central to this -- I cant stress enough just how different real spherical rotation (spinor) is to the common concept of rotation. No one will fully understand untill you see the animations and play with the parameters -- lots of them.
One of the rare posts I made a while ago is here http://marksnoswell.cgsociety.org/gallery/329928 it's rough and unedited but will interest the readers here.
I believe I have a good conceptual model that fits with current theories but simply explains what is happening in areas that embarass current theories -- things like black holes, renormalization, and the ratio of gravity to electromagnetic forces. When I find time to present it well I'll put it up on the web. It also appears to fit with a number of features people ar stumbling onto in areas such as the TPU -- it also neatly supports Randal Mills CQM. However what is most encouraging is that it has suggested practical devices and experiments which are exhibiting predictable and novel features in early research.
AH -- I see I miss read the attachment limitation previously -- I can upload some of the animations. Attached is a recent development I made -- it's a simple three shell solution for a spinor. There are three nested shells - each linkes to the next. There is a simple harmonic rotation on each shell as shown. This demonstrates the application of 3 components -- two at a fundamental frequency and one at the second harmonic -- that combine to create a spinor. I made this development in response to the desire to come up with a spinor fomulation that I coul make from nested coils. I believe that this (and it's topoligical equivelants) is the simplest posible formulation of a spinor. The practical side of the research is in early stages but appears to support the theory so far.
goto go now.
cheers.
Mark.
Dr Mark Snoswell.
MarkSnoswell
Originally posted at http://www.overunity.com/index.php/topic,2637.72.html
just time for some quick notes...
Must have pulses for (efficent) OU effects... you need a spin wave front. If the core effect is due to spin waves fronts driving spinor resonance then the timing of component signals within SM TPU configuration will not be what you expect -- Start with full control of pulse timing and separation for three drive coils and just tune up one at a time.
Drive coils dont need to be closed -- leave them open circuit and it will still work (with dramatically lower input requirment). It's the spin pulse on potential jump that is the motive force. This is the pulse Edison engineers noticed and Tesla called the radiant pulse. By wrapping a collector wire with the drive coil the resulting spin wave front drives current down the central collector coil -- this is what SM alluded to as "like squezing water along a hose". (Ideally the potential pulse is so short that it can be contained within a percentage of the drive coil -- there will be an optimum pulse width but that probably a lot shorter then anyone is using at present.)
Static bias potentials -- both electric and magnetic -- can/need-to be controled for tuning. (This can be used to modulate the output for ease of matching/forming to power grid frequency.)
There is an exponential relationship of static potential to output -- drive with high voltage pulses for maximum effect. Conversly you will have a hard time tuning devices with low voltage pulses.
Start with sine waves and you wont get anywhere. -- you will get lots of nice rotating fields but no easy access to interesting effects.
cheers
mark.
Dr Mark Snoswell.
MarkSnoswell
Originally posted at http://www.overunity.com/index.php/topic,2637.75.html
Quote from: Jdo300 on July 13, 2007, 01:56:09 PM
The "second harmonic component" seems to line up with your idea of using x, 2x, x harmonics. Can the effect still work if all three frequencies are the same and just phase shifted?
No. In principal -- 3 in phase signals in 3 non-linked coils just vectorially add to a single component. You need independant control of pulse timing and the right coil design... but this is all based on work I have done simulating spinors. This work seems to fit SM and other devices better than any other theory I have seen but thats no guarantee that its right. Right now I am trying to extend my spinor generation software (a plugin within 3ds max) so I can search for higher order frequency relationships. I expect that exact phase timings will depend on the physical relationship of the coils -- there will also be different timings (harmonics) you can drive at given a single physical setup.
What is certain is that three independant components are required to create spinors. There is a huge range of physical ways to generate these components. There is also a corresponding large range of potential signal sets to create different spinors. As SM said -- start with one drive and then just vary the second component looking for maximum output... and then add the third and itterate to improve. After you have a set of timings that work then you can start to experiment with resonant feedback.
hm... if I get a chance over the next few days I'll put up an animation that makes this all clearer.
Mark.
PS. In some ways SM's TPU designs are sloppy -- at a guess about 10 years behind a competive technology. Although interesting effects seem easy to get *precise* physical designs should result in even more suprising effects. Whatever people make they should strive for very neat construction and be aware of small design changes that influence the output. As a hint look at Randal Mills work with generating Hydrinos and ask yourself how a low energy (reduced spin) electron from a hydrino would behave as a charge carrier in a wire.
Mark.
Dr Mark Snoswell.
