Tubes?
Started by Super God, July 18, 2007, 06:46:18 PM
pese
I have start 1950 , to work with tubes (In fatger radio-repair-shop
and buid radio- transmitterns , also audio ampliers and all kind of devices. Also done this later pressional.
I know als the wrintings  this tubesfrom tesla- car to SM with
his Recrifier Tubes .
I have all kind from this tubes (used , from US-Military electronic
equipments in my stock.
BUT...forget this circuits , it cant work this way
Pese
http://ch.to/tubes
BEP
@Pese
Yes. This tube cannot be the one that switches high power to a coil. It is designed for small signals.
But it could be used as the control for a gated rectifier. One with a plate cap. Perhaps those used as TV beam deflection switches for the horizontal deflection transformer?
pese
Jes but als bigtups that work wit 300volt and 0,5 amps,
will not work. The design of cicuits is not know to find FE.
Possible from "NOISE" (great bandwth frequencies?) Tesla-Car?
Altat ist possibel with Tube , canbe done also with semiconductors.
Relais , Sparks and so on.
All FE desings are to find frequencies and harmoiccs of them , than will be ADD other frequencies (and Power) in the designed citcuit (devices) .  mechanical , electric , magnetic , caloric , nuclear OR any othe way .
THIS is to find out . After this , it can be examinate if you will
do this with tubes or other  way,
Only to think, old  "exotic" devices , can possibly "bring" Overunity ... IS THE WRONG WAY
G.Pese
innovation_station
about old things steven said it would be much easyer to get the thing to work using tubes also in the vid link i posted when they sweep the freq you will notice there is a verry tight window for the freq to make the coil ringg also when the signal gets to the other end of the coil it flips phase with the meter then is sent back through with the next pluse and so on
so if there was a tube sending siginal and another tube phase inverting the siginal at the end of the coil well if the tubes were the ones they spoke of in the video then each time a pluse came throught to the tube it will kock more electrons off in side the tube with  each pluse so the electricty will grow with each pluse
well
also steven said lamp wire for the collectors works best  he also said 3 collectors stacked all have control winds on them in 3 or more segements  now if we apply this to the tpu we might have some luck
ok in the vid remember how the magnetic feilds increase near the end of the coil and the caps are the oppsite so what if
collector 1 has 3 coils on it and 3 caps and the mag feild goes like this  coil1 weak coil 2 stronger coil 3 strongest then the next layer  goes the same only turned by 120 deg and the same with the top layer out of phase by 120 deg each layer
so what i am saying is this
pluse collector 1 then 2 then 3 and you are passing a verry strong mag feild all around the collectors
steven said that we will need several hundred  thousand kicks per second to combine all togather at the same freq to make a big usable kick or output power
1 more thing steven said
IT WAS NOT DIFFICUALT AT ALL!!!!!!!
im sure steven has told us much more than we even need to know about the tpu
yesterday i was plusing a trans former backward right out of my freq gen and it was set to 12 v and i plused 1 set of wires and when i hit the right freq for the transformer it would humm big time with no magnets and i mesured the output of the transformer and it was over 70v ac at the right freq for the transformer no useable power but if i put a fet or a high speed switch to turn off and on 12v dc at 2-3 amps im sure i would have useable output power so what if you had 3 transformers plused backward each feeding 1 of the 3 collector layers and each of the layers out of phase by 120 deg so then i would be putting about 70v or so through each of my 3 layers and i should then have a verry strong mag feild racing around a ring so im guessing when we hit the right speed of the ring all 3 layers that are out of phase will make a constant huge mag feild and surround the ring compleatly just as though it was a constant input
so i guess what im think ing is this make 3 coils each diffrent freqs or diffrent harmonicas of the same freq
im gonna leave it there 4 now
i had 1 more thought about the ring
what about this  when we cancel the flux of the ring  inside of the ring does that cancel the flux to the earth?  if it does it makes sence when you turn it upside down it will not work
if that is right then it is like we are pluging our tpu in to the earth and traping power from it in the ring and only letting out of it what we want to use from it if that is correct then it is like we have connected it with the earth or set in in vibration with the earth
well all from me for a bit back to the bench
ist
Super God
Yeah, IS has the right idea I think.  I'm doing the same with three collectors on top of each other.  SM seems to talk about the collectors more than the controls in his letters?  I figured he would want to explain more about the controls...
>9000
