Tubes?
Started by Super God, July 18, 2007, 06:46:18 PM
innovation_station
sg
fets are inside of the tpu why? why are they called fets? do fets not stand for feild effect? transistors
tubes are outside the ring all of them
what is the reason for tubes?  what  will be diffrent in the ss units then the tube 1? hummmmm a spark gap??
does a tube not do both switch and have a spark type gap in a vacume  a spark gap in a vacume with ss would be required to act the same as a tube
another thing if we intend to discharge a cap into a ring using freqs how many freqs do we have in a tpu?
well the sm 17 sedjusts that there 2 freqs cuz ther 2 caps being discharged  into the center or the outter or both so if there 2 freqs then there 2 beat freqs for each freq wich might just be first fundamintal freq and second harmnic for the first beat freq then the second might be 3 harmonic and 4th haromonic or the ring is tuned just a bit more than the first fundumental freq say 7.3 hz then the first freq of the second beat freq would be 7.3 more than the first fundumntal freq of the first combo and for the second beat it would be second haromonic of the second fundumental freq  so what would happin will there would be massicve ringing at 7.3 hz on the fundumental freqs and all harmonics
now if we add a 3 freq of high speed  what happins not a beat freq just a stright freq at say 100k then that make manny haromonics i have seen 7th plus harominc with high speed  or the speed is made on its own with the racing mags
i have an old square and sine wave generator tube powered but i dont think the generator is important  ;)
i got  verry intresting waves on my scope using my laptop and a verry simple proggie for osolations  so i dont think a tube freq generator is required  our freq generator must do more than 1 job   ;)
it must osc and it must switch at the same time and maybe even more than that well yes more than that how about it is the "processor" of the tpu so it must control dc voltage to the controls it must supply ac to the collectors it must be the spark gap ans must be the timming control so the tube sounds like a verry busy part of the tpu    ;)
steven makes a remark about the tpu  goes somthing like this
you can have many currents in 1 wire only pertaing to there own source what might that mean?
that to me means ac and dc in the same wire maybe the collectors then keep the ac in them and only take the dc to the controls then back to there source or the end of the controls are open and it will now transmitt wirelessly as long as it is stoped b4 the end of the controls plus it would be transmittinf from the perpendicular controls if you look at the sm 17 it has in its center 2 coils of 2 controls each  also what if this we sent power through collector outside ring then to the center to transmitt back to the collector kinda of makes me wonder because all of the wires running back to the center of the coil  the sm 17 it must be ss because of the spark gaps on the back  it is almost like it is 4 segments all the way through
is
is
turbo
well, Steven was using three tube based signal generators when he first strike those magical tones.
and that means i will use tube based eqipment too :)
here's a pic of the ancient triple varicaps i will use to build them :)
M.
Thaelin
   I remember thoes for sure. Old radios. On a good note, I just got a pair of 1X2B 1/2 wave rectifiers. Rated at 22,000v peak. Sounds as if they were used for the HV on a crt or such. 1.25 v 200ma filament. Time to play!
thaelin
Super God
Quote from: -[marco]- on August 08, 2007, 08:12:36 AM
M.
Dude I am so jealous of your tube equipment.  Good luck on your experiments though!  I will soon be joing you!  By the way are those homemade or are they old models or...something else?  Is there anyway I can get ahold of the same equipment you've got? (Signal generators and so forth)
>9000
pese
ilin
no this 1X2  europe DY80 to 86  are jes for 22KV  but was not Eadio , it was vor Television (Blach/White) . also an smalone only 6mmx6cm tube  - Dy60 or 51  , US number vant remember jet ..
most build (in splug)  in the horizomtal Line Transformer. to make the High Voltage for CRT Tube (Picture Screen)
After tgis it comes same als selenn rectiviers 16KV (abozt 6mm x 12cm ceramic within hunders of seleen diode wafers.
For stromger TV - Colot  it guve som kind of GY 500 series. tube (See philips mullard telefungen
als in US  in the 5 Volt range  (# begins with 5)
In Radio  only (usually)6x4  (ez41 m 89 81 90  enz)
for strong eqipments 5U4 5R4  and so on (all in the 500 Volt working range)
All Numer take from head , but i think all must be right so.
its are 50 jears gone , since i worked  any day with this parts
G.Pese
