Tubes?
Started by Super God, July 18, 2007, 06:46:18 PM
Grumpy
Like a damn "soap opera" in here.
SM used tubes to determine the frequencies - detectors.  Something about SS being too slow to see them.  Once this task was done - no tubes.
Very sharp pulses will create harmonics in the microwave region.
        -Frank Edwards
innovation_station
thank you grumpy
can you clear a few more things up ? so we can fly down the path
i for 1 would love to get there i thought that was the case at 1 point too but i have started over agin
tubes make it easy to get it to work and get all the right freqs and# after you have those you can then make the ss units
sounds like a post i made a wile ago lol!!! hummm..
i beleave sm made a quote somthing like this if you knew how much power you can convert from a permeant magnet ,,,,, i could start over on that topic alone
many things will be discovered reserching this technolagy  ;)
SO ITS ALL GOOD!!!!!!
IS
xilusma
is
"what i mean we will now have 500v dc at 3 amps!!"
We have the same "frequency" for that.  :)  Still need to test it and make it work.
use energy wisely - dare to dream
Grumpy
Quote from: innovation_station on August 24, 2007, 12:23:43 AM
thank you grumpy
IS
First question is to ask yourself what the hell you are trying to do.
Obviously, tubes are not the only way - just a means to an end - might ponder what a "high impedence" realy does to an electric field - why would a tube see something that SS are toos low to see?
        -Frank Edwards
Mannix
Quote from: Grumpy on August 24, 2007, 12:02:33 AM
the term "harmonic perfection" will not fit the above,unless I am mistaken.
The gap between tubes and ss was ten years....after having this process running.
To dismiss tubes for others is only ok IF you have been successful in doing so otherwise so I disagree with this for now and at least untill several hundersed different things are explored using the devices that we have been told to use so that it will be easier.
Any other aproach is less likely to achieve results...but of course nothing is impossible.
We have seen the videos...ss units!
It is like  showing a cave man a box of matches and making fire ...then leaving him to it..with some sulphur..Then  somebody tells  him not to use that yellow stuff (sulfur) because we know that match heads are red...
