Tubes?
Started by Super God, July 18, 2007, 06:46:18 PM
turbo
if you are going to drive the tubes with ss generators, i suggest you put the sensitive circuitry inside a shielded metal box and use heavy shielded grounded signal carrying wires.
But it was made clear to us more then once, it is not how it was discoverd by the master aswell as it will be extremly difficult to get results, he even said it took him years to get the things to run on ss.
why not take the road exactly like he did and do things right?
shortcuts only seem to save some time...but do they? :)
Marco.
BEP
Perhaps Pese can answer this question but I'm open to ideas:
If we are talking about rotation of the electrostatic field would it be beneficial to place the tubes in any certain place or orientation within the coils?
I've found no evidence of this but I'm thinking it may be possible to 'enhance' the particle flow in the tube.
Ideas anyone? (technical please  :)
turbo
hi BEP
the electron flow in tubes can also be infuenced by a strong magnetic field.
this is similar in a cathode ray tube where the magnetic field draws the line on the mask.
the field "steers" the beam and moves it over the end of the tube screen at high speed.
a speed human eyes cannot follow so we are simply thinking we see a complete picture but in fact it is made up of many lines, one at a time.
but i guess everybody knows this.
on the yoke are placed several magnets to set up a carefully balanced magnetic field, this is much like they balance the wheel of a car with tiny pieces of lead so it won't vibrate while driving....
if the field is not carefully balanced, the picture on the screen would deform.
so we can influence electric fields with magnets and magnetic fields with electric fields.
it is possible that in the exploding television, the coils of the yoke were placed closely to some tubes, thereby creating some sort of magnetic feedback ,not much at first ,but as the tubes get older the microphonic effect will increase, and this could be the reason for the event to happen.
Marco.
BEP
So 'enhancement' may be a stretch of imagination but feedback certainly would not.
I remember the echoing and reverb effects I used to get on my old Kenwood when the pre-amps started to glow blue.
Think of this - a tube that is intended to be effected by fields. One might call it a VFET   ;D
Bias the grid at the cliff of triggering - let the passing wave take it over the edge to start a new step in oscillation ???
Or use the same method to turn an oscillator on or off each time around the circle at the same point regardless of the oscillator frequency. If that was done the best place for the tubes would be between the plates/collectors and not the center of the mess.
If an idea that wild was used I could see why going from tubes to SS would be a giant leap!
innovation_station
@ marco
are you ready to use the rest of the tubes ,transformers and variable caps you already bought for the next test if in fact you are i will walk the walk if you are not i wont because im tired of wasteing time and  what im working on the output of my machine will far exceed the tpu in operation in every way  ;D and im not boasting but i want them both DONE!!! ASAP!! LOL!!!
but if i see no further progress on the tpu i will find it hard to waste more time on it
just think of 2012
how much time is left b4 choas ?!?!?!?!
NOT ENOUGH !!!
WILLIAM
