The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
Devil
Disclosing information as Christmas Present
Tseung, Do not take the advice of Top Gun.  Human Beings are basically lazy and stupid.
You have disclosed the Lead-Out Energy theory for years.  Some Government institutions took it and developed top-secret projects.  Others just jeer and insult.
When things are free, Human Beings will not value them.
Just continue your development path.  Produce the 5KW electricity generator.  Do not hope that someone will do it for you.  It took you et al six years to develop the 1 watt overunity prototype.  It will not take that long to develop the 5KW generator.  Believe in yourself and your team.  Give them the encouragement.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
chrisC
Quote from: Devil on December 15, 2009, 12:45:17 AM
old Tseung: Don't you feel stupid playing childish games like this?
For a 60 plus old man, are you missing your childhood? Even first graders don't do what you do now! Shame on you! Try not to do this after the New Year. How about a New Year resolution to behave like a 60 plus grandpa?
cheers
chrisC
markdansie
@Lawrence
well if it took 6 years to develop the 1 watt overunity at this rate if we multiply 5000 (5kw) by 6 years for every watt I have calculated we should have your unit in another 30,000 years.
However if you had your other personalities who post here assist you, (Top Gun and Devil) we might have someting in much less time.
PS still waiting for independent verification with a paper that can be perr reviewed.
Kind Regards
Mark
Paul-R
Quote from: markdansie on December 15, 2009, 03:07:01 PM
@Lawrence
This is one watt overunity more than you have ever developed.
And if you had ever got off your lazy backside and bought a SSG kit,
I wouldn't be able to taunt you thus.
ltseung888
Christmas Gift to  the World
To be realistic, different persons have different background and capabilities.  This is much more pronounced in accepting revolutionary inventions.  Let me classified them into the following groups.
1.   The Genius who got the inspiration â€" Like Mr. Lee Cheung Kin.  Everyone has seen the pendulum.  No one before him suggested that the pulled pendulum can lead-out gravitational energy.  (Everyone has seen things falling.  No one before Newton suggested gravitational force).
2.   The brilliant physicists â€" Like Lawrence Tseung.  He applied the necessary mathematics and physics to the Lee suggestion and confirmed that the Lead-Out energy theory does not violate the Law of Conservation of Energy.  Gravitational and Electron Motion energy can be lead-out.  He can extend the theory from oscillation to vibration, rotation and from gravity to magnetic, electric and electron motion fields.
3.   The top guns â€" Like the professors at Tsing Hua University in China.  They understood the theory as soon as it was explained to them.  They could do their own independent research.  Many researchers at top-secret institutions also fall into this category.
4.   The top engineers â€" Like Tong Po Chi.  He can convert the concept into an actual prototype.  Six other groups failed before him.  He built the prototypes in stages.  The stages included Coil and Magnet Interaction; selection of air coils; selection of the proximity switch; building different size wheels; tuning via number of Drive or Collector Coils, different loads etc.
5.   The open-minded scientists â€" Like Dr. Patrick Tsang and Dr. James Wong.  They can listen to the theory and see the prototype in action.  They can read the meters and the oscilloscopes.  They can understand the Lead-Out Energy theory and re-explain it to others.
6.   The intelligent students â€" Like Forever, Debbie, Miller etc.  They can study the theory and the prototype.  They can help out in the presentations.
7.   The general public.  Some wanted to see the final product in their homes.  Some wanted to see verifications from Established Authorities â€" they could read the meters but they felt that was only the surface.  Some felt the magnitude of the Invention â€" can some retired scientists with practically no resources in Hong Kong revolutionize the World?  Are they witnessing a miracle themselves?
8.   The jeerers and insulters.  Some of them are paid to disrupt the development of this technology.  They just hurled negative remarks and made noises.  They did serve one purpose â€" draw in the crowd.  If the theory and the prototype actually work, their disruptive tactics are doomed to fail.
The 2009 Christmas Gift to the World at this stage is simple.
The working prototype consists of:
1.   A  60 cm diameter rotating wheel with 16 equally spaced magnets.
2.   A 80 cm diameter non-rotating wheel with 15 Coils and 1 proximity switch.
3.   The magnets are custom-made rectangular pieces with poles on the flat sides.
4.   The coils are 0.5 mm wires with approximately 6 ohms resistance.
5.   The proximity switch is the 12-24 DC volt version.
6.   The relay is the SSR version that can take up to 40 amps.
7.   The Output must be rectified to DC for use and comparison.
8.   The requirement of the engineering is that the 16 magnets and the 15 coils + Proximity Switch must be built to face each other with less than 1 mm tolerance.  The Proximity Switch needs to be adjustable to get the best result.
9.   The connecting wires must be thick enough to tolerate the occasional current of over 10 amps.
10.   The building process must be carefully planned and executed.  Every coil must be connected in the right way.  No iron pieces must be attracted to the strong magnets in the rotating wheel.
The best way is for a factory to produce well-manufactured parts and come up with either a completed or a Do-It-Yourself version.  The winding of the coils (over 500 turns) could not be done by hand and produce consistent quality.  All holes must be predrilled with the high precision required.
Government research laboratories and Universities will be able to meet the above requirements easily.  The average garage mechanic will have difficulties.
This is the Christmas Gift to the World in 2009.
*** Hopefully, the Christmas Gift to the World in 2010 can be purchased in the retail stores. ***
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
