The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
Devil
Tseung, I accused you of stupidity.  You accept it in silence.
Now I shall teach you how to be clever.
You should openly declare that you would not answer any post from anyone who cannot understand or agree that:
It is the vertical component of the tension times the vertical displacement that gives the work done by Gravity.
You and Top Gun will not need to go round in circles, repeat and repeat the same stupid arguments.
Your posting the HK$10,000 reward is effectively for anyone to disprove the above statement.  Nobody can possibly win.
Be clever.  No professional debunker or scientists can overturn the above statement.  You do not need to defend the obvious Lee-Tseung Theory.  Attack, attack and attack.  Your invincible weapon is:
Make it your daily prayer to me!
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
hansvonlieven
Quote from: Devil on May 21, 2008, 06:08:14 AM
You should kneel before me and recite:
?. A hundred times.
What an idiotic statement to make. As long as the body hangs on a string NO work is being done by gravity or anything else. It might as well be a rock lying on the ground. You should study the difference between energy and potential energy you moron.
Hans von Lieven
shruggedatlas
Quote from: Devil on May 21, 2008, 07:31:47 PM
The reward is meaningless if there is not an impartial third party judge who would decide whether the theory is disproven.
chrisC
Quote from: shruggedatlas on May 21, 2008, 08:32:07 PM
@shruggedatlas
You can look at it this way.... it's like arguing which end old Tseung talks through.Whether the words come from the mouth or through the rear end, it's equally meaningless when there's no truth!
cheers
chrisC
Devil
Quote from: hansvonlieven on May 21, 2008, 08:19:19 PM
Hans von Lieven
Hans, you must be very brave to call me, the Devil, an idiot.  The statement is:
QuoteIt is the vertical component of the tension times the vertical displacement that gives the work done by Gravity.
It applies to the case of the pendulum under a Lee-Tseung pull.  The statement is correct so long as there is tension on the string.
You are more stupid than most.  You already posted the loudspeaker that does not need input energy.  That uses the Lee-Tseung pull in a vibration environment.  Electron motion energy is lead out.
You should apply the word idiot to yourself.
In your case, your daily prayer to me should be:
Repeat it a hundred times daily.
