Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
This is the Bob Boyce TPU thread.
Bruce_TPU
Build Page 1
The Bob Boyce Toroidal Power Unit Replication Parts List and Suppliers
1.  Core -  T650-52
Micrometals, Inc. Home Office
http://www.micrometals.com/contactus_index.html
Address:  5615 E. La Palma Avenue
Anaheim, CA 92807 USA
Phone:
714-970-9400
Toll Free in US:
1-800-356-5977
Fax:
1-714-970-0400
E-Mail:
sales@micrometals.com
2.  Bee's Wax
Toilet bowl wax seal from your local building supply store
3.  Bias Winding
This winding is 48 turns of 20 guage magnet wire on this particular core.
4.  Winding tape
Can be obtained from suppliers that carry electric motor and transformer rewind supplies.
Surplus source for electrical winding tape:
http://www.surplussales.com/RF/RFTeflon-Mylar.html
The yellow, non-stretchy, thin stuff is polyester (Mylar is a brand name - of 3M - I think) - look for the yellow roll on the page.  These prices are a little cheaper than standard pricing.
5.  Woven fiberglass sleeving
Skycraft Parts & Surplus  (See #6 for contact information.)
6.  Secondary winding
a.  16ga solid copper, silver coated wire.  Somewhere around 90' or so. 131 turns seems to fit well. A bit more turns if no longitudinals are wound underneath.
Business Hours (E.S.T.)
Mon-Fri: 8:30 - 6:00 p.m.
Saturday: 8:30 - 5:00 p.m.
Sunday: Closed
2245 West Fairbanks Ave.
Winter Park, FL 32789
Tel. (407) 628-5634
Fax (407) 647-4831
b.  Home Depot for some 0.080" weedwacker line. This was cut into 133 little pieces 1.5" long each.
c.  Vitamin C powder bottle
7.  Secondary Winding Tool
I had to make up a small spool that could pass through the toroid hole. This was made from a 3 1/2" long piece of 1" electrical PVC tubing solvent welded to a couple of 2 3/4" diameter discs. These were cut from 1/4" PVC sheet. I turned these on the lathe so they would fit over the ends of the tubing.
8.  Primaries (3 or 6.  Recommend 6 primary windings)
20ga solid copper, silver coated wire
Same source as #6 above
Hex Controller
(Future Information)
Bruce_TPU
Build page 2
The Bob Boyce Toroidal Power Unit Photo Journal
All future updates will be able to be downloaded from this post:
Please download the newest Bob Boyce Working Toroidal Power Unit > V.1.5.PDF
located at the bottom of the page!
Motorcoach1
Thank youÃ,  Stefan and Bruce -Ã,   now it will be eseryer to keep updating on progress.Ã,  toroids are ordered and still searching for silver wire and getting all parts for PCB board. in Bobs form i have the PMW#3 and he mentioned something about specific parts that fit the board is that still a go?Ã,  I know this is a new PCB board but does the parts issue still apply, Mike    PS -to all put a short cut on your desk top to this thread and go strait to the thread :)
MarkSnoswell
Excelent -- a private space :)
I have a core now but am about to run out of time untill September. I will be availble on-line but because of business travel I wont be able to experiment.
I do hope to get a few hours this weekend to do some basic experiments on longitudinal wave transmission -- I have a stack of long solenoid coils (for various tesla coils) laying around that I want to do some tests with. As it's a capacitivley coupled advanced wave we want I have some ideas I want to test for more efficent drives... I'l post some photos whatever happens.
cheers
Mark.
Dr Mark Snoswell.
President of the CGSociety www.cgsociety.org
