Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bruce_TPU
Quote from: Bob Boyce on July 27, 2007, 11:14:22 AM
Hi all
Sorry I haven't posted earlier. A storm blasted through and took out the phone lines again. One of the drawbacks of rural living, this area loses power and phone lines every time a thunderstorm rolls through. I'm the only one around here that still has power during power grid outages, but I can't do anything about phone lines ;-)
I just wanted to touch base and let you all know I have been pretty busy, but hope to spend time out in the shop today. Before I wind my secondary on this core, I am going to go ahead and add some more longitudinal windings. This way they will already be there in case I want to do some testing with them later.
No problem on the proprietary controller... I will be releasing a basic version of my HexController, which is based on the Atmel AT-Mega48 microcontroller running with an external 20 Mhz clock for stability. I have it in alpha test with a replicator in Florida, wanted to make sure there were no trace errors prior to release. I had stopped working on it mid-design, so had to complete it on my own time. That basic version was designed prior to my being contracted to design a deluxe version, so it is not bound by the agreement. I will be more than happy to share it with the group for testing.
Bob
Hi there Bob!
Great to have you here with us!  I look forward to release of your basic HexController.  It should help everyone in their design work.
I for one am curious of the "second layer" of windings you are putting over your longitudal (solenoid) windings.  This would have to be aimed at increasing the overall "magnetic bias" or field strength of this solenoid winding, to see if that affects overall performance or power.  Would that be an accurate guess?  And are you thinking of adding more than one layer extra of windings?
Happy days,  :)
Bruce
Bob Boyce
Quote from: tao on July 26, 2007, 11:55:21 PM@Bob
You mentioned that you were running an electric golf cart of one of your toroids. Can you give us any more details on that, like how far you could drive before the energy surges happened and stopped you? I am just trying to 'gauge' how much energy we can be realistically expecting from our builds here...
If you don't want to answer this question it is ok. About how many watts of power do you anticipate these toroids will be able to continuously output once we finally have our systems stable? , which might be easier said than done...
ANY OU at all is incredible and will change all of our worlds here, but I was just curious anyway.
I was not able to run the golf cart with that early 3 phase experiment. Every time I would disconnect the battery it would avalanche, destroying the controller,  speed control, and melting the wiring. Everything I had been told by others was telling me that in order to prove the design I had to disconnect the battery. Since I could not do this without damage, I gave up and went back to the low powered single phase design for simple battery charging. It did not avalanche.
The power output can be anywhere from a few hundred watts to a couple of kilowatts on the safer side. More can be had at greater risk of losing control. Bias potential and magnetic bias play a large role in how much output can be obtained for a given amount of drive energy.
Bob
Grumpy
Quote from: Bob Boyce on July 27, 2007, 10:57:58 AM
Quote from: Grumpy on July 26, 2007, 11:18:16 PM
@Bob  Boyce
What are the three states of dominant energy?
Polar
Parapolar
Diapolar
Bob
One can easily corellate these to magnetism:
Polar - ferromagnetic - self sustaining
parapolar - paramagnetic - aligns with ferromagnetic
diapolar - diamagnetic - aligns opposite ferromagnetic
I do not think that these actually corellate like this, but the arrangement is the same - para is same and dia is opposite.
What is the physical significance of the three states?  Can you elaborate on how the achieve these states?
Thanks Much
        -Frank Edwards
Bob Boyce
Quote from: Grumpy on July 27, 2007, 11:43:28 AM
@Bob  Boyce
Polar
Parapolar
Diapolar
Bob
Thanks Much
Sorry, thought about that after I had posted. I should have offered the following;
Polar = anomolous electrical / magnetic effects
Parapolar = anomolous heating / cooling effects
Diapolar = anomolous gravitational effects
3 variations of a common thread. Many anomolies observed are results of unbalanced mixes of 2 or more of these. It's just a theory and I really don't care about theory as much as actual hands-on research and experimentation.
Bob
HumblePie
