Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bob Boyce
The woven fiberglass sleeving was cut to size, installed on the longitudinal winding leads, and the core taped up a bit more with winding tape. I marked top and bottom for reference.
Bob
Bob Boyce
I had to make up a small spool that could pass through the toroid hole. This was made from a 3 1/2" long piece of 1" electrical PVC tubing solvent welded to a couple of 2 3/4" diameter discs. These were cut from 1/4" PVC sheet. I turned these on the lathe so they would fit over the ends of the tubing.
I began winding the secondary. This will take me a while to wind and space evenly considering I get tired easy ;-)
Bob
weri812
hi All
Got my fiberglass sleeve from  Skycraft Parts & Surplus ,
along with the wire i needed.
Now i wait.
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
Bruce_TPU
Quote from: Bob Boyce on August 03, 2007, 06:13:47 PM
Bob
Hi Bob,
Not a problem, we are a patient bunch.  (Most of the time... ;))  We are all waiting for our cores any way.  I for one would enjoy seeing a picture of your little winding spool that you made.  Also, do you already know how many feet of wire is required for the secondary winding?
Quote from: weri812 on August 03, 2007, 08:01:24 PM
hi All
Now i wait.
wer
Thank you Wer, and that is very good information as well.
Bruce
weri812
taking in the extra windings and tape
useing 16ga tifflon coating  at 200 turns will be a little
over 117 ft
